Wall Temperature in Nozzle with RhoCentralFoam
Old   February 10, 2016, 20:16
Default Wall Temperature in Nozzle with RhoCentralFoam
Hilbert
Hillie is on a distinguished road
Dear Foamers,
I have been working on a nozzle simulation with rhoCentralFoam. I have a CFX solution which I am currently using as a baseline.
The core-flow matches up beautifully with the CFX results. The wall pressure is also looks very nice, and compares very well. My current issue is with the wall temperature.
I have a large drop in wall temperature in my throat, which recovers after my throat to about 3 degrees lower then my CFX baseline.
My temperature B.C at the well is zero gradient, i.e adiabatic wall. If I compute the adiabatic wall temperature for my case it look like the CFX solution is right.
The wall shear is also over predicted w.r.t the CFX solution. Which would suggest an over prediction of the velocity wall gradient. Yplus is of order 1, and checkmesh also checks out.
My fvSchemes file is currently set to the following:
fluxScheme      Tadmor;
ddtSchemes
    default         Euler;
gradSchemes
     default               leastSquares;
    grad(U)                cellLimited leastSquares 1;
    grad(rho)              cellLimited leastSquares 1;
    grad(omega)            cellLimited leastSquares 1;
    grad(k)                cellLimited leastSquares 1;
divSchemes
    default          none;
    div(tauMC)       Gauss linear;
    div(phi,U)       Gauss linear;
    div(phid,p)      Gauss linear;
    div(phi,K)       Gauss linear;
    div(phi,h)       Gauss Gamma 1;
    div(phi,k)       Gauss Gamma 1;
    div(phi,epsilon) Gauss linear;
    div(phi,R)       Gauss Gamma 1;
    div(phi,omega)   Gauss Gamma 1;
    div((rho*R))     Gauss Gamma 1;
    div(R)           Gauss Gamma 1;
    div(U)           Gauss linear;
    div((muEff*dev2(T(grad(U))))) Gauss linear;
    div(yPhi,yWall)  Gauss linear ;
laplacianSchemes
    default         none;
   laplacian(muEff,U) Gauss Gamma phi 1 corrected;
    laplacian(alphaEff,e) Gauss Gamma phi 1 corrected;
    laplacian((rho*DomegaEff),omega)  Gauss Gamma phi 1 corrected;
    laplacian((rho*DkEff),k) Gauss Gamma phi 1 corrected;
    laplacian(yPsi)   Gauss Gamma phi 1 corrected;
    laplacian(yWall)   Gauss Gamma phi 1 corrected;
interpolationSchemes
    default            linear;
    reconstruct(rho)   Gamma 1;
    reconstruct(U)     GammaV 1;
    reconstruct(T)     Gamma 1;
    interpolate(rhoU)  Gamma pos 1;
    interpolate(rho)   Gamma pos 1;
snGradSchemes
    default         corrected;
wallDist
      method advectionDiffusion;
        // Optional entry enabling the calculation
        // of the normal-to-wall field
        nRequired false;
         advectionDiffusionCoeffs
             method    Poisson;
             epsilon   0.4;
             tolerance 1e-3;
             maxIter   20;
If anybody has any idea's on what I could use to get the wall temperature up those last couple of degrees that would be grand.
Hillie is offline   Reply With Quote
Old   August 25, 2024, 09:03
Gaoqiang Yang
shanyeyun is on a distinguished road
Hi, have you solved this problem?
I have met same problems, i.e. pressure and temperature seems correct at the center line of nozzle. However, the wall temperature is not correct, which is increasing along the flow direction (It should be decreasing )
shanyeyun is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
How to adjust wall temperature nutow FLUENT 0 September 4, 2011 06:37
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
About the wall temperature zt_zt FLUENT 3 May 12, 2003 09:09
