Using thermoFOAM over porousSimpleFoam simulation
Old   February 10, 2016, 06:22
Default Using thermoFOAM over porousSimpleFoam simulation
styleo86 is on a distinguished road
Hi Foamers,
I have done several external aero simulation with porousSimpleFoam with KomegaSST turbulence model, now I have to implement energy equation in those simulations.
After some not working tests with rhoPorousSimpleFoam, I have found thermoFoam application. As listed in OF official guide thermoFoam
evolves the thermodynamics on a frozen flow field, so I have a question, Can I use this application over my old simulations in order to have the temperature field?
Best Regards,
Leonardo
styleo86 is offline   Reply With Quote
Old   February 15, 2016, 21:03
Yan Wang
wayne14 is on a distinguished road
Hi Leonardo,
It depends. But normally the effect of temperature on the flow field is not negligible, so it's not a good idea to solve temperature on a frozen flow field.
I would recommend you to use buoyantBoussinesqSimpleFoam or buoyantSimpleFoam, where the coupling between temperature field and flow field is solved. And the porous part can be easily accounted for using fvOptions.
Regards,
Yan
wayne14 is offline   Reply With Quote
Waterbell Simulation o.b.m Fluent Multiphase 1 November 5, 2015 06:55
setting up a simulation with multiple interactions phandy OpenFOAM Running, Solving & CFD 1 October 6, 2014 04:16
mass flow rate issue in supersonic nozzle simulation xkang FLUENT 0 July 31, 2014 17:06
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 15:29
