Conjugate heat transfer boundary conditions problem
Old   February 4, 2016, 04:17
Default Conjugate heat transfer boundary conditions problem
Gregor Alan
GregorAlan is on a distinguished road
Dear all,
For my first conjugate heat transfer problem I have made two Fluent meshes and imported these succesfully and merged these (ran checkMesh and it says ok apart from some non-orthogonal faces). Then I have used topoSet to define 2 cellZonesSets the 'pin' part and the 'topAir' part, which are an aluminium cylindrical pin and the fluid flowing around it.
I run 'splitMeshRegions -cellZonesOnly -overwrite' and it creates 2 regions as expected.
I have coupled the walls of the 'pin' which are in contact with the 'topAir' with the following boundary conditions which are in the changeDictionary file like this:
dictionaryReplacement
T
internalField uniform 300;
boundaryField
pin_wall
type compressible::turbulentTemperatureCoupledBaffleMix ed;
Tnbr T;
kappa fluidThermo;
kappaName none;
value uniform 300;
type fixedValue;
value uniform 300;
pin_bottom
Tnbr T;
kappa fluidThermo;
kappaName none;
value uniform 300;
And similarly for the topAir changeDictionary.
Then changeDictionary runs fine, but chtMutiRegionFoam gives this error message:
--> FOAM FATAL ERROR:
patch type 'wall' not type 'mappedPatchBase'
for patch pin_wall of field T in file "/home/gregor/OpenFOAM/my_icoFoam_simulations/CHT_mutiple_msh/0.002/pin/T"
From function turbulentTemperatureCoupledBaffleMixedFvPatchScala rField::turbulentTemperatureCoupledBaffleMixedFvPa tchScalarField
const fvPatch& p,
const DimensionedField<scalar, volMesh>& iF,
const dictionary& dict
in file turbulentFluidThermoModels/derivedFvPatchFields/turbulentTemperatureCoupledBaffleMixed/turbulentTemperatureCoupledBaffleMixedFvPatchScala rField.C at line 105.
FOAM exiting
Does anybody know why it is doing this?
Regards,
Gregor
GregorAlan is offline   Reply With Quote
Old   February 4, 2016, 05:24
akidess's Avatar
Anton Kidess
Your base patch specification in your polyMesh/boundary is set to wall, when it should be mapped.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   February 4, 2016, 05:49
Gregor Alan
In the polyMesh/boundary file it already says:
topAir_to_pin
type mappedWall;
inGroups 1(wall);
nFaces 2054;
startFace 39620;
sampleMode nearestPatchFace;
sampleRegion pin;
samplePatch pin_to_topAir;
And the other way around as well.
This is only present in the split meshes polyMesh folders (so in the first time step folder). Should this also be somewhere else? In /constant/polyMesh they are all type wall or patch.
Kind regards,
Gregor Alan
Old   February 4, 2016, 11:24
akidess's Avatar
Anton Kidess
Why did you post "topAir_to_pin" when the error message was for "pin_wall"?
Old   February 4, 2016, 11:47
Gregor Alan
I'm now at a different error, it says it reads a file 0.001/topAir/h, but this file doesn't exits.
Create time
Create fluid mesh for region topAir for time = 0.001
Create solid mesh for region pin for time = 0.001
*** Reading fluid mesh thermophysical properties for region topAir
Adding to thermoFluid
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
Adding to rhoFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to hRefFluid
Adding to ghFluid
Adding to ghfFluid
Adding to turbulence
Selecting turbulence model type laminar
Selecting radiationModel none
Adding to KFluid
Adding to dpdtFluid
Adding MRF
No MRF models present
Adding fvOptions
No finite volume options present
*** Reading solid mesh thermophysical properties for region pin
Adding to thermos
type heSolidThermo;
transport constIso;
thermo hConst;
equationOfState rhoConst;
specie specie;
Adding to radiations
Adding fvOptions
Region: topAir Courant Number mean: 0.032191039 max: 3.9437706
Region: pin Diffusion Number mean: 0.00026157047 max: 0.0010890305
deltaT = 0.00015213753
Region: topAir Courant Number mean: 0.0048974652 max: 0.59999553
Region: pin Diffusion Number mean: 3.9794687e-05 max: 0.00016568242
Time = 0.00115214
Solving for fluid region topAir
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 1.4921893e-09, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 3.9820263e-10, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 1.8649883e-08, No Iterations 2
gradientInternalCoeffs cannot be called for a calculatedFvPatchField
on patch topAir_to_pin of field h in file "/home/gregor/OpenFOAM/my_icoFoam_simulations/CHT_mutiple_msh/0.001/topAir/h"
You are probably trying to solve for a field with a default boundary condition.
From function calculatedFvPatchField<Type>::gradientInternalCoef fs() const
in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 199.
FOAM exiting
Any suggestions?
Old   February 4, 2016, 12:19
Bloerb will become famous soon enough
Your boundary conditions are most likely ill defined.
Please do the following
run checkMesh -region ... after splitMeshRegions to check if both region meshes are valid.
After executing changeDictionary check polyMesh/boundary and 0/region.../T if all boundary conditions are correct. If you are unsure please post them here.
In addition...why does it say "time = 0.001"? Is this your startTime?
Is your pin region a solid? If so why have you put fluidThermo instead of solidThermo into the boundary condition?
Bloerb is offline   Reply With Quote
Old   February 5, 2016, 04:21
Gregor Alan
I corrected the fluidThermo to solidThermo.
The reason why it says 0.001 is that it is my startTime. Moreover, if I use mergeMesh to merge the two fluent meshes and then 'topoSet' and 'splitMeshRegions -cellZonesOnly -overwrite'. This creates a new time folder with the two split meshes which I then copy manually to the constant/region folders.
So after running checkMesh -region topAir:
Create time
Create polyMesh topAir for time = 0
Time = 0
Mesh stats
faces: 61354
internal faces: 57183
cells: 26765
faces per cell: 4.4288063
boundary patches: 9
point zones: 0
face zones: 0
cell zones: 2
Overall number of cells of each type:
hexahedra: 0
prisms: 11290
wedges: 0
pyramids: 187
tet wedges: 0
tetrahedra: 15288
polyhedra: 0
Checking topology...
****Duplicate boundary patch 1 named topAir_to_pin of type mappedWall.
Suppressing future warnings.
***Boundary definition is in error.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
topAir_to_pin 167 236 ok (non-closed singly connected)
topAir_to_pin 68 45 ok (non-closed singly connected)
slice_top 344 298 ok (non-closed singly connected)
slice_side_1 832 450 ok (non-closed singly connected)
slice_side_2 826 447 ok (non-closed singly connected)
inlet_slice 150 95 ok (non-closed singly connected)
outlet_slice 70 51 ok (non-closed singly connected)
bottom 149 97 ok (non-closed singly connected)
topAir_to_pin 1565 979 multiply connected (shared edge)
<<Writing 50 conflicting points to set nonManifoldPoints
Checking geometry...
Overall domain bounding box (0 0 -0.005) (0.05 0.01 0.035)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (2.1324352e-17 -3.2357735e-16 9.8175178e-18) OK.
Max cell openness = 4.3025992e-16 OK.
Max aspect ratio = 18.062411 OK.
Minimum face area = 2.4664557e-08. Maximum face area = 9.6183031e-06. Face area magnitudes OK.
Min volume = 9.7573986e-12. Max volume = 9.098178e-09. Total volume = 1.8638727e-05. Cell volumes OK.
Mesh non-orthogonality Max: 76.57185 average: 13.971542
*Number of severely non-orthogonal (> 70 degrees) faces: 45.
Non-orthogonality check OK.
<<Writing 45 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 1.0477446 OK.
Coupled point location match (average 0) OK.
Mesh OK.
Time = 0.001
Mesh stats
faces: 61354
cells: 26765
boundary patches: 9
point zones: 0
face zones: 0
cell zones: 2
hexahedra: 0
prisms: 11290
wedges: 0
pyramids: 187
tet wedges: 0
tetrahedra: 15288
polyhedra: 0
Point usage OK.
Face vertices OK.
Face pyramids OK.
Mesh OK.
End
I am a bit confused as to what the solver needs for coupling the solid region to the fluid region. Do I need to add mappedWalIs manually to the polyMesh/boundary file? I did it like this for the pin (the pin top is the only one not in contact with the solid):
4
pin_wall_to_topAir
type mappedWall;
inGroups 1(wall);
nFaces 1506;
startFace 49399;
sampleRegion topAir;
samplePatch topAir_to_pin_wall;
pin_top
type wall;
inGroups 1(wall);
nFaces 238;
startFace 50905;
pin_bottom_to_topAir
type mappedWall;
inGroups 1(wall);
nFaces 238;
startFace 51143;
samplePatch topAir_to_pin_bottom;
pin_to_topAir
type mappedWall;
inGroups 1(wall);
nFaces 1565;
startFace 51381;
samplePatch topAir_to_pin;
The changeDictionaryDict for topAir is as follows:
U
internalField uniform (0 0 0);
boundaryField
pin_wall_slice
type fixedValue;
value uniform (0 0 0);
pin_bottom_slice
type fixedValue;
slice_top
type slip;
slice_side_1
type slip;
slice_side_2
type slip;
inlet_slice
type fixedValue;
value uniform (3 0 0);
outlet_slice
type zeroGradient;
bottom
type fixedValue;
T
boundaryField
type fixedValue;
value uniform 300;
pin_wall_slice
Tnbr T;
kappa fluidThermo;
kappaName none;
value uniform 300;
pin_bottom_slice
Tnbr T;
kappa fluidThermo;
kappaName none;
value uniform 300;
p_rgh
internalField uniform 1e5;
boundaryField
pin_wall_slice
type inletOutlet;
inletValue uniform (0 0 0);
value uniform (0.1 0 0);
pin_bottom_slice
type fixedValue;
slice_top
type fixedValue;
slice_side_1
type inletOutlet;
slice_side_2
type inletOutlet;
inlet_slice
type inletOutlet;
outlet_slice
type inletOutlet;
bottom
type inletOutlet;
p
boundaryField
pin_wall_slice
type inletOutlet;
pin_bottom_slice
type fixedValue;
slice_top
type fixedValue;
slice_side_1
type inletOutlet;
slice_side_2
type inletOutlet;
inlet_slice
type inletOutlet;
outlet_slice
type inletOutlet;
bottom
type inletOutlet;
Maybe if you want I can attach the case folder?
Old   March 31, 2016, 17:53
Diego Vaca
diegofutbolero is on a distinguished road
I am running OF 2.1.1 wuth chtMultiRegionSimple solver.To run the case I use ./Allrun. However: I have the following error:
patch type 'patch' not type 'mappedPatchBase'
for patch CO2_to_SS316 of field T in file "/home/diego/OpenFOAM/Kruizenga-StraightChannels-2/0/CO2/T"
const fvPatch& p,
in file derivedFvPatchFields/turbulentTemperatureCoupledBaffleMixed/turbulentTemperatureCoupledBaffleMixedFvPatchScala rField.C at line 99.
My BC for the both regions are:
CO2_to_SS316
neighbourFieldName T;
K basicThermo;
KName none;
value uniform 298.15;
SS316_to_CO2
K solidThermo;
KName none;
Any help will be very appreciated
diegofutbolero is offline   Reply With Quote
Old   April 7, 2016, 18:10
In your polyMesh boundary files you need to change the definition of both patches to a mapped patch instead of patch
Old   January 30, 2021, 06:29
cal
saidc. is on a distinguished road
Hi Bloerb,
I had the same problem in T file (' not type 'mappedPatchBase' for patch wall of field T in file) then i read this post and changed boundary files. Now i'm getting this error:
Cannot find patchField entry for fluid_to_sphere
Any suggestion?
Best regards,
Said.
fluid/boundary
inlet
type patch;
nFaces 214;
startFace 165423;
outlet
type patch;
nFaces 242;
startFace 165637;
wall
type mappedWall; //was wall
inGroups List<word> 1(wall);
nFaces 4664;
startFace 165879;
sampleRegion sphere;
samplePatch sphere_to_fluid;
fluid_to_sphere
type mappedWall;
nFaces 4186;
startFace 170543;
polyMesh/boundary
inlet
type patch;
nFaces 214;
startFace 380986;
outlet
type patch;
nFaces 242;
startFace 381200;
wall
type wall;
nFaces 4664;
startFace 381442;
T
inlet
type fixedValue;
value uniform $Tinitial;
outlet
type inletOutlet;
inletValue uniform $Tinitial;
wall
kappa kappa;
Tnbr T;
saidc. is offline   Reply With Quote
Old   January 31, 2021, 13:13
cal
I realized what I was doing wrong, I made a silly mistake. One of the boundary conditions in T was missing and I changed it, now it's working.
Best regards,
Said.
fluid/boundary
inlet
type patch;
nFaces 214;
startFace 165423;
outlet
type patch;
nFaces 242;
startFace 165637;
wall
type wall;
nFaces 4664;
startFace 165879;
fluid_to_sphere
type mappedWall;
nFaces 4186;
startFace 170543;
T
inlet
type fixedValue;
outlet
type inletOutlet;
wall
type zeroGradient;
fluid_to_sphere
kappa kappa;
Tnbr T;
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 12:14
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
