A problem using reactingParcelFoam to simulate turbulence |
February 3, 2016, 06:03 |
Yuzheng
Rep Power: 11 |
hello,
I got a problem using reactingParcelFoam to simulate turbulence. The results of LES model and RAS model are very similar. However, if I chose pisoFoam, the results of LES model and RAS model are quite different. So I am eager to know how to use reactingParcelFoam with LES model. Thank you very much! |
February 3, 2016, 11:43 |
Yuzheng
Rep Power: 11 |
Can anyone help me?
problem with using fan BC to simulate turbine. | hujianxiao62 | FLUENT | 0 | June 2, 2015 00:15 |
Turbulence kinetic energy and dissipation rate - problem with computation | Kozan | Main CFD Forum | 0 | March 6, 2015 05:04 |
divergence problem with turbulence | tH3f0rC3 | OpenFOAM | 4 | April 6, 2011 11:14 |
I have a problem about the turbulence flow! | yuchang | FLUENT | 6 | June 27, 2003 01:50 |
Starwatch problem and turbulence length unit | Jiaying Xu | Siemens | 0 | August 18, 2001 11:57 |
