Floating point exception after changing from straight pipe to bend |
Zeno
Rep Power: 12 ![]() |
I simulated a straight pipe like the one you see in the figure below with uniform bc's for U, k and epsilon and everything went fine. I then used the same bc's and configuration files to simulate a bend like the one in figure below but I get 'floating point exception' and the simulation crashes before the first iteration. Can anyone give me a hint on what's happening here? Best, Z |
Artur
Rep Power: 20 ![]() |
If it crashes before the 1st iteration something is definitely wrong with your setup or, more likely, the new mesh. Posting the actual log file would help. Run checkMesh -allTopology -allGeometry as well to convince yourself there aren't any obvious errors in the grid.
All the best, A |
floating point error, pipe bend |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 11:43 |
[PyFoam] having problems with pyfoam Installation | vitorspadetoventurin | OpenFOAM Community Contributions | 3 | December 2, 2014 07:18 |
Pipe flow in settlingFoam floating point exception | jochemvandenbosch | OpenFOAM Running, Solving & CFD | 4 | February 16, 2012 03:24 |
Floating point exception error with small DeltaT | rassilon | OpenFOAM Running, Solving & CFD | 19 | September 2, 2009 07:39 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
