Floating point exception with simpleFoam
Old   January 25, 2016, 09:35
Exclamation Floating point exception with simpleFoam
AndreiCFD
andrei.cimpoeru is on a distinguished road
Hi All,
I am trying to run simpleFoam on the highlift geometry (high lift prediction workshop 1). I've created a mesh myself in Pointwise, I set up the test case and simpleFoam gives floating point on the very first cycle. I cannot upload the grids since it is very big (35M cells). The problem is that I was able to run other solvers on the same mesh and it seems OK.
I have used fixedValues at the inflow and zeroGradient at the outflow. The problem is that simpleFoam fails when is trying to solve pressure equation. I tried to drop the order of the discretisation from 2nd to first and no chance to get it to run.
I would like to know if anyone experienced the same problem and how they fixed it.
I would appreciate your help and many thanks.
Cheers,
Andrei
andrei.cimpoeru is offline   Reply With Quote
Old   January 26, 2016, 04:51
Default fvSchemes and fvSolution
Odranoel is on a distinguished road
could you post your system/fvSchemes and system/fvSolution? Usually the problem is caused by GAMG solver for pressure; I will suggest you to switch to PCG.
Alternatively you could launch the command 'renumberMesh -overwrite' (remeber to make a copy of your constant folder before) and keep on using GAMG.
Odranoel is offline   Reply With Quote
Old   January 26, 2016, 06:50
AndreiCFD
Originally Posted by Odranoel View Post
Thanks for the reply Odranoel. The first thing I did when the test case failed I switched to a conjugate gradient method for the pressure equation and it didn't work. Also I also run renumberMesh -overwrite and it failed with thing as well.
Please see the attached system file and I would be grateful if you find any mistakes. Much appreciated for your suggestions .
Cheers,
Andrei
Old   January 26, 2016, 10:21
Hi Andrei,
it seems to be everything ok.
I would just remove the library included in controlDict (I think they are useless in this case), but I don't think it will solve the problem.
Did you try to run potentialFoam? Did checkMesh show errors?
Sorry for not being so helpful.
Old   January 26, 2016, 12:03
AndreiCFD
Hi Andrei,
Hi Odranoel,
No worries. I tried all sorts of things. The thing is that potentialFoam is failing as well. checkMesh gave have some related to some high aspect ratio cells. The thing is that in the past I was able to run even on very bad meshes compared with what I have now. The thing is that I have slip conditions on my farfield regions. I am just thinking if this can cause problems. Have you had any problems with the slip conditions? Thanks for you help this is the error.
Create time
Create mesh for time = 0
Reading field p
Reading field U
Floating point exception (core dumped)
Old   January 27, 2016, 09:44
Hi Andrei,
I never tried slip conditions at farfield but I don't think it's the problem because the check of U and p (before core dumped) is ok. By the way you can try to switch to zeroGradient or freestream just to be sure.
You can check the file polymesh/boundary if you have the same patch of BC; I am still thinking it's a mesh problem. Did you change the controlDict?
Let me know if something changes.
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 12:43
Floating point exception (core dumped), running a new solver Mahyar Javidi OpenFOAM Running, Solving & CFD 6 April 7, 2018 13:43
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 20:28
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 17:23
Pipe flow in settlingFoam floating point exception jochemvandenbosch OpenFOAM Running, Solving & CFD 4 February 16, 2012 04:24
