pipe with orifice, pressure drop declines when pipe gets longer (BC problem?)
Old   January 21, 2016, 05:55
Default pipe with orifice, pressure drop declines when pipe gets longer (BC problem?)
Christof Schmidt
cristopf is on a distinguished road
Hi everybody,
I hope anybody can help me out with my case. Iīve got a pipe with an orifice in it. Inlet is on the left and outlet on the right side. I have a turbulence air flow solving with simple foam and want to calculate the pressure drop between Inlet and Outlet.
Inlet:
internalField uniform (0 0 0);
boundaryField
inlet_solid
type fixedValue;
value uniform (4.63 0 0);
outlet_solid
type zeroGradient;
walls_solid
type fixedValue;
value uniform (0 0 0);
Outlet:
internalField uniform 0;
boundaryField
inlet_solid
type zeroGradient;
outlet_solid
type fixedValue;
value uniform 0;
walls_solid
type zeroGradient;
two cases (attached pictures):
1. short pipe
2. the second pipe is longer after the orifice
The problem is that I get a fewer pressure drop for the longer pipe.
short pipe: dp=63.5 Pa
long pipe: dp=53.5 Pa
short pipe: I assume that the problem is the boundary condition p=0 at the outlet. Perhaps that condition conflicts with the "chaotic" flow profile at the outlet.
long pipe: in that case the flow at the outlet "calmed down". (so I think value of pressure drop more plausible for that case)
How can I change the boundary conditions to get a more accurate value for the pressure drop for the short pipe (if thatīs the reason)?
I thought about to work with the type calculated for the pressure at the outlet
cristopf is offline   Reply With Quote
Discharge of Pressure Vessel into Pipe with Regulator gajowni2 System Analysis 0 October 31, 2015 19:57
Orifice-Pipe Problem CFXMUFFIN CFX 3 July 16, 2015 19:57
Pipe line pressure drop kirli OpenFOAM Running, Solving & CFD 2 March 1, 2013 17:13
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
