Ship hull with appendage as seperate patch runs into error
Old   January 21, 2016, 05:24
Default Ship hull with appendage as seperate patch runs into error
Manoj
manoj_nav is on a distinguished road
Hi Everyone
My ship hull has an appendage below the hull. My objective is to find out wave resistance on hull and total force on the appendage.. With this in mind, I was trying to do a simulation with the hull and appendage as separate patches, so as to report the forces separately. I was trying to do a dynamic trim and sinkage simulation to account for the trim and sinakge that the hull with incur at the given speed. But when I run the simulation it gives error. I have attached the log file as well as the setup file. I have also trying running it without 6Dof utility and in serial, but I get same error.
Error:
[5] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[5] #1 Foam::sigFpe::sigHandler(int) at ??:?
[5] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
[5] #3 Foam:ICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) at ??:?
[5] #4 Foam:ICSmoother:ICSmoother(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:?
[5] #5 Foam::lduMatrix::smoother::addsymMatrixConstructor ToTable<Foam:ICSmoother>::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:?
[5] #6 Foam::lduMatrix::smoother::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::dictionary const&) at ??:?
[5] #7 Foam::GAMGSolver::initVcycle(Foam::PtrList<Foam::F ield<double> >&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::lduMatrix::smoother>&, Foam::Field<double>&, Foam::Field<double>&) const at ??:?
[5] #8 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[5] #9 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
[5] #10 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
[5] #11 Foam::fvMatrix<double>::solve() at ??:?
[5] #12 ? at ??:?
[5] #13 ? at ??:?
[5] #14 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[5] #15 ? at ??:?
Please help me to run it correctly.
I am using Openfoam 3.0.0.
Regards,
Manoj
manoj_nav is offline   Reply With Quote
Old   March 13, 2016, 10:12
Artur's Avatar
Artur
Artur will become famous soon enough
Since the error happens before the solver executes and when solving for correctPhi I take it it's most likely due to the mesh. Can you try running checkMesh and reporting the outcome?
A
Artur is offline   Reply With Quote
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 21:16
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
