Error in MPPICFoam when using Implicit packing model
Old   January 17, 2016, 04:29
Default Error in MPPICFoam when using Implicit packing model
Victor Koppejan
vkoppejan is on a distinguished road
Hi Everyone,
I'm getting the following error when running MPPICFoam in serial using the Implicit packing model (HarrisCrighton particle stress model).
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::PackingModels::Implicit<Foam::MPPICCloud<Foa m::KinematicCloud<Foam::Cloud<Foam::MPPICParcel<Fo am::KinematicParcel<Foam:article> > > > > >::velocityCorrection(Foam::MPPICParcel<Foam::Kine maticParcel<Foam:article> >&, double) const at ??:?
#4 ? at ??:?
#5 ? at ??:?
#6 ? at ??:?
#7 ? at ??:?
#8 ? at ??:?
#9 ? at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? at ??:?
I'm using the following setting in kinematic cloud properties
implicitCoeffs
alphaMin 0.0001;
rhoMin 1000;
applyGravity true;
particleStressModel
type HarrisCrighton;
alphaPacked 0.65;
pSolid 100;
beta 3;
eps 1.0e-2;
Psolid and beta values were taken from Snider 1998. The system is a liquid-solid system.
I gone through the velocityCorrection function but I have no idea what to look for.
Thanks in advance for you help.
Victor
vkoppejan is offline   Reply With Quote
Old   January 17, 2016, 11:23
Default Solved
Victor Koppejan
I think problems were the empty boundary conditions, which don't seem to work with the velocity correction function.
Changing them to slip for velocity and zerogradient for pressure solves the problem.
Turbulence model choice dave13 CFX 3 December 22, 2015 08:12
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
problem with solving lagrange reaction cloud Polli OpenFOAM Running, Solving & CFD 0 April 30, 2014 08:53
manualInjection model in sprayFoam Mentalo OpenFOAM Running, Solving & CFD 1 April 2, 2014 10:29
