simpleFoam error --- Foam::symGaussSeidelSmoother |
January 14, 2016, 05:31 |
Dear all,
I am getting a strange error when running simpleFoam both in serial and parallel. I have run a couple of of tutorials to check my OF installation is correct, and that checks out. I have created the mesh with GridPro, exported it and get one mesh failure when running checkMesh, i.e. "Faces not in upper triangular order" This might be the reason. I'm attaching the logs I get, in case someone can help me understand what's going on, both the log from simpleFoam (*.simpleFoam) and the output to screen (*.toScreen) and the log for checkMesh (log.checkMesh, along with the case files. Thanks in advance! Carlos >>>>>>>>>>>>>>> Exported mesh to Fluent format and run fluentMeshToFoam <mesh> -writeSets -writeZones <<<<<<<<<<<<<<< Last edited by aerospain; January 14, 2016 at 07:35. Reason: PROBLEM RESOLVED (for now ...) |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 16:26 |
MPI error with simpleFoam | blaise | OpenFOAM Running, Solving & CFD | 0 | November 7, 2015 15:01 |
simpleFoam parallel solver & Fluent polyhedral mesh | Zlatko | OpenFOAM Running, Solving & CFD | 3 | September 26, 2014 07:53 |
Laminar simpleFoam and inviscid simpleFoam | herenger | OpenFOAM Running, Solving & CFD | 7 | July 11, 2013 07:27 |
Trying to run a benchmark case with simpleFoam | spsb | OpenFOAM | 3 | February 24, 2012 10:07 |
