January 13, 2016, 14:17 |
Running buoyantPimpleFoam in parallel
Amir Abbas Aliabadi
Rep Power: 13 |
Hello Dear Colleagues,
I have successfully set up a case for simulating airflow over a heated cavity (urban canyon) using buoyantPimpleFoam. I have cyclic boundary conditions in the span-wise and stream-wise direction and I initiate flow by applying a pressure jump using fixedJump BC at inlet and outlet. The simulation runs fine on single core but when I parallelize it using decomposeParDict and MPI after some iterations my Courant number increases and finally the solution diverges. I am using the "simple" method with 4 to 27 subdomains. I have tried various combinations such as (4 1 1), (1 4 1), (1 1 4), (2 2 1) etc. for 4 subdomains, ... and (3 3 3) for 27 subdomains. No matter how fine I make the time step, I do get the solution diverging after some iterations. Is there any recommendation or references I can read to help me parallelize this solver effectively? Thank You! Amir |
error while running in parallel using openmpi on local mc 6 processors | suryawanshi_nitin | OpenFOAM | 10 | February 22, 2017 22:33 |
Running mapFields with Parallel Source and Parallel Target | RDanks | OpenFOAM Pre-Processing | 4 | August 2, 2016 06:24 |
running OpenFoam in parallel | vishwa | OpenFOAM Running, Solving & CFD | 22 | August 2, 2015 09:53 |
Unconsistent parallel jobs running time | arnaud6 | OpenFOAM Running, Solving & CFD | 4 | February 10, 2015 13:42 |
Problems running in parallel - missing controlDict | Argen | OpenFOAM Running, Solving & CFD | 4 | June 7, 2012 04:50 |
