strange u+ values with LES-Smagorinsky
Old   January 7, 2016, 11:03
Default strange u+ values with LES-Smagorinsky
Matej Muller
matejmuller is on a distinguished road
Hello!
I'm getting strange u+ values by using LES with Smagorinsky (see attachment).
I'm modeling open channel flow, my y+ values are under 1 (around 0.6), for the wall boundary condition i'm using:
nuSgs --> nutUSpaldingWallFunction
U --> fixedValue uniform (0 0 0)
p_rgh --> zeroGradient
alpha.water --> zeroGradient
The mesh refinement towards the wall is linear with a step around 1.2.
It seems like the u+ values follow a linear law in the viscous and logaritmic region.
With a coarser mesh, where y+ is greater then 30, the results are OK (the u+ values follow the logaritmic law).
Has anyone experienced the same issues? In my knowledge one can use y+=1 values in LES models because of the vanDriest damping. Is the openfoam LES model limited only for y+ values in the logaritmic region (this is y+>30).
Regards, Matej
matejmuller is offline   Reply With Quote
Old   January 7, 2016, 12:50
sheaker's Avatar
Oskar
sheaker is on a distinguished road
Hello.
I'm not sure but as I know y+ should be from 10 to 300.
CFL should be < 1.
sheaker is offline   Reply With Quote
Old   January 8, 2016, 07:08
Matej Muller
Hi!
Thanks for the reply... Yes, it looks like it is only suitable for larger y+ values, regardless the van Driest damping...or the damping is to big, considering that the u+ values behave linear also in the logaritmic region?...i'm not sure
Maybe my LESproperties are not well defined? I've used the properties from the tutorial with delta set to vanDriest.
regards, matej
No rms values for LES lofty OpenFOAM Running, Solving & CFD 18 December 24, 2018 14:09
Incomp. LES in pisoFOAM, how to set up Smagorinsky model with van Driest dampin Jan.Östh OpenFOAM Running, Solving & CFD 21 August 10, 2016 13:03
LES smagorinsky and SST turbulence drsidd10 CFX 1 January 10, 2015 05:59
Dynamic Smagorinsky LES Lourival FLUENT 0 April 14, 2006 14:48
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 10:58
