Compressible steady state solution divergence |
December 29, 2015, 01:41 |
Nihar
Rep Power: 12 |
Hi everyone
I am trying to run a steady state compressible solution using rhoSimpleFoam for my research project. My problem involves an engine intake valve simulation but since it was diverging to make sure the correctness of my setup I ran the same simulation for a simple cylinder case, but the solution still blows up, so I am confident that the problem is in either my boundary conditions or numerical schemes. The logfile shows very high time step continuity errors. I am applying fixedPressure boundary conditions for pressure at inlet and outlet as it's a pressure guided flow, and I have used pressureInletVelocity for the inlet velocity BC. I tried to change the boundary conditions to inlet mass flow rate to see if fixedPressure BC at both inlet and outlet was creating a problem but the solution still blows. For the numerical schemes, I tried using first order upwind as it's the most stable but that doesn't help. Reducing the under relaxation factors just delay the divergence but doesn't help otherwise. I have reached a dead end here and any help will be appreciated. I have attached my boundary conditions and numerical schemes files. Thanks. Nihar |
December 29, 2015, 05:27 |
W.T
Rep Power: 14 |
Can you attach a logfile ?
Using fixedValue for pressure on inlet and outlet is not good idea - you fixed static pressure difference between in and out so velocity will rise in every iteration and finaly "blow up" simulation. Try use totalPressure instead of fixedValue BC on inlet. Also the steady state compressible solvers in OF often require "soft start" - if you will use massFlowRate on inlet define it as a table - small mass flow on start, target flow rate after few hundred iteration. If you want to have pressure guided flow use uniformTotalPressure BC on inlet and also define it as table. |
January 1, 2016, 02:56 |
Nihar
Rep Power: 12 |
I changed the boundary conditions as you had suggested. Following is my new pressure BC at the inlet.
a00000009_Inlet { type uniformTotalPressure U U; phi phi; rho rho; psi none; gamma 1.4; pressure table ( (0 93001) (100 100000) ); } Unfortunately that doesn't help and the solution is still diverging after a few iterations. I have attached the log file. Another thing is when I turned off the turbulence parameters the solution didn't diverge. After around 5000 iterations it still hasn't converged either, but the mass flow rate I am getting is pretty close to the experimental value. I wonder why this is happening. |
January 6, 2016, 06:12 |
Nihar
Rep Power: 12 |
I tried multiple set of boundary conditions with constant pressure set at inlet and outlet, but the simulation blows up every time. If I change it to a constant mass flow rate inlet, it runs fine, so I am positive there is some issue when running a steady state solver for a pressure guided flow.
Has anyone faced a similar problem? |
January 8, 2016, 05:47 |
#5 | |
Rep Power: 16 |
you can try to do something like that for velocity inlet BC: Quote:
For pressure you should use zero Gradient at inlet and fixedValue at the outlet. Kind regards Chrisi |
January 12, 2016, 10:57 |
Nihar
Rep Power: 12 |
But I have to fix the inlet pressure, so I can't set zeroGradient at inlet.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Solver for transonic flow? | Martin Hegedus | OpenFOAM Running, Solving & CFD | 22 | December 16, 2015 05:59 |
Steady State solution | ajinkya1 | SU2 | 2 | November 26, 2014 05:22 |
Steady State Solution animation | rmageddon | FLUENT | 1 | April 19, 2014 01:38 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 15:37 |
