How can I get stedaystate solution from pisoFoam?
Old   December 8, 2015, 05:31
Default How can I get stedaystate solution from pisoFoam?
Jun
mykkujinu2201 is on a distinguished road
Hi, everyone.
I have a question about pisoFoam.
I know for steadystate, simpleFoam is adequate but what if I wanna find steady state solution using pisoFoam?
Currently, I'm working on MHD solver. I found some code on the internet but it is based on PISO Foam.
I set steadyState at fvScheme but it only made errors.
Few steps and stopped.
So, I though it is maybe because of PISO algorithms. So, I checked pisoFoam at Steady state and it showed same error.
mykkujinu2201 is offline   Reply With Quote
Old   December 8, 2015, 08:37
Ferdinand Pfender
FerdiFuchs is on a distinguished road
pisoFoam is not able to give you a steady state solution.
only if your problem itself is a steady state problem, then it should be possible.
What you maybe lookin for is averaging a value over the whole domain (fieldAverage) via functionObjects-Library.
But beware, unsteady simulation and averaging is much˛ more time consuming then using a steady-state solver!
This is how it should look like in your controlDict for mean and prime2mean of U and p
functions
fieldAverage1
type fieldAverage;
functionObjectLibs ( "libfieldFunctionObjects.so" );
enabled true;
outputControl outputTime;
fields
U
mean on;
prime2Mean on;
base time;
p
mean on;
prime2Mean on;
base time;
FerdiFuchs is offline   Reply With Quote
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 22:22
Analytic solution for 2D steady Euler equations jojo81 Main CFD Forum 0 October 15, 2012 13:05
Solution divergence in pisoFoam (Co <1) enoch OpenFOAM Running, Solving & CFD 0 May 16, 2012 22:35
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
