Boundary conditions outlet
Old   November 27, 2015, 07:34
Default Boundary conditions outlet
Sarah Leenknegt
SarahLee is on a distinguished road
Dear,
I am trying to solve a simple test case (2 inlets, 2 outlets, buoyant flow, steady state, incompressible) and have problems with defining my outlets so they behave as I want.
Details
- inlet 1
velocity: fixed velocity
pressure: fixedfluxpressure
pressure_rgh: fixedfluxpressure
temperature: fixedvalue
- inlet 2
- outlet 1
velocity: flowrateinletvelocity (positive, patch outlet)
- outlet 2
velocity: pressureInletOutletVelocity(patch outlet)
pressure_rgh: totalpressure
The idea is that I define the total inflow through the inlets, I define the outflow via one of the outlets and the continuity results in the correct outflow via the second outlet.
However, I get too high outflow over outlet 1 and additional outflow over outlet 2. The mass balance just doesn't make sense..
What am I doing wrong?
Thank you!
Sarah
SarahLee is offline   Reply With Quote
Old   November 28, 2015, 10:34
Joachim Herb
jherb is on a distinguished road
Have you tried calculated for the pressure boundaries? Also for the outflow regions fixedValue for temperatures does not sound correctly. Better should be zeroGradient or inletOutlet.
jherb is offline   Reply With Quote
buoyancy driven flow, incomp, outlet boundary condition, pressure and velocity
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
