November 17, 2015, 20:05 |
Equations solved by potentialFoam
Thomas Oliveira
Rep Power: 12 |
The OpenFOAM Extend Wiki explains that the equations solved by potentialFoam are:
Is that really what potentialFoam does? (I wasn't able to figure out by reading the file potentialFoam.C) If it is, why does it make sense? I understood that the correct way to solve for the pressure in a potential flow field would be to first solve , from compute , and then compute using Bernoulli's principle. Thanks! |
potential flow, potentialfoam |
Navier Stokes Equations solved by commercial CFD codes | D.B | Main CFD Forum | 5 | September 9, 2015 05:45 |
Shallow water equations | Rime | Main CFD Forum | 3 | August 30, 2015 00:20 |
kEpsilon and pisoFoam: when transport equations for k and eps are solved | LuisAlberto | OpenFOAM Programming & Development | 5 | August 24, 2015 06:33 |
SIMPLE Algorithm Finite Difference Equations: how to discretize and solve? | DA6righthand | Main CFD Forum | 0 | August 3, 2015 13:12 |
? fluctuating equations for homogenous shear turb. | ff_fan | Main CFD Forum | 1 | September 20, 2002 08:39 |
