VOF interFoam - Strange behaviour in a micro T-junction |
May 21, 2018, 09:17 |
#21 |
Anik Sarker
Rep Power: 9 |
could anyone please upload the case file ?
It could be helpful for others. |
August 27, 2019, 12:18 |
vof modeling in micro channel in fluent
#22 |
maryam
Rep Power: 9 |
hi
i am simulating a model with two vents and one outlet.the water patched into the main chamber and air can goes in and out from two vents. i want to simulating water flow in channel.the model in 3d and modeled in fluent i dont have any parameters in vents what is the best boundary condition for them? the vents are in the atmosphere pressure but the whole model is rotating so i dont know the gauge pressure=0 in correct for these vents or not? i use the out flow for outlet which it is incompatible with pressure boundaries. i cant see the right flow in channel is there any one could help me? the residuals cant decrease enough and continuity residuals are in order of 10 i appreciate your recommendations |
July 28, 2023, 15:11 |
#23 |
Santhosh
Rep Power: 4 |
Hello Pablo,
It is been a while since the thread but your subject is really close to my research. I am simulating two phase flow in micro T-junction too and using interFoam. By mimicking experimental conditions, I manage to get emulsion of the same length/shape as my experiments but not the same mean velocity or periodic generation. Did you encounter those difficulties as well ? Or do you have any advice/hints ? Thanks for your time! Sincerely, Santhosh |
Strange behaviour when using compressibleInterFoam with constantAlphaContactAngle | TobM | OpenFOAM Running, Solving & CFD | 2 | May 11, 2016 06:34 |
Strange temperature behaviour with interFoam | tayo | OpenFOAM | 9 | July 11, 2014 07:28 |
strange pressure behaviour with symmetricPlane boudary condition - interFoam | duongquaphim | OpenFOAM Running, Solving & CFD | 10 | August 20, 2013 14:00 |
Strange boundary behaviour using interFoam | Andrea_85 | OpenFOAM | 11 | January 22, 2013 15:09 |
Strange behaviour because of contact angle (interfoam) | Kim123 | OpenFOAM Running, Solving & CFD | 0 | January 12, 2011 10:16 |
