Rotation of airfoil in a fluid domain using dynamic mesh
Old   November 14, 2015, 21:35
Default Rotation of airfoil in a fluid domain using dynamic mesh
Abhishek Saraf
abhisheksaraf is on a distinguished road
Send a message via Skype™ to abhisheksaraf
Hey there
I have started to work on openfoam recently so do not mind if you find my questions silly. So, I have a case where I have used block mesh to define a mesh around an airfoil
The airfoil has been defined as a patch. Now I want to specify a rotation to the airfoil about the centre and add and remove layers when the mesh around it gets skewed or squeezed or expanded.
In this regard I was looking at the pimpleDymFoam tutorials but there an example of the fluttering wing is given. I want to have the same case but specify the motion in terms of angular velocity.
I am a little confused on how to proceed on this, as I am new to openfoam.Kindly suggest in ways on how I should proceed.
abhisheksaraf is offline   Reply With Quote
dynamic meshing, mesh motion, pimpledymfoam
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? RPjack ANSYS Meshing & Geometry 2 August 27, 2015 10:33
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
[ICEM] Hybrid Mesh on 2D airfoil Jrmy ANSYS Meshing & Geometry 2 August 14, 2014 16:08
