icoFsiNonLinULSolidFoam with mesh topology change ( DynamicTopoFvMesh class) |
November 12, 2015, 16:28 |
rasoul
Rep Power: 11 |
hello foamers
I am using icoFsiNonLinULSolidFoam solver for simulating the one way valve. Because of extreme change of valve's throat area , DynamicMotionFvMesh class is not a good scheme for my case. I want to know that , can this solver support other dynamic scheme defining in foam-extend-3.1 ( for example dynamicTopoFvMesh or dynamicRefineFvMesh , etc) for re-meshing or refining the regions that have bad meshes during solution . Could you help me to solve this problem Best Regards |
April 18, 2016, 11:58 |
Bartosz Żłobiński
Rep Power: 11 |
As far as I know, meshing is completely independant from solver, so other classes should work also with icoFsiNonLinULSolidFoam. I'm working on similar topic. Maybe I could say more soon. Best regards, Bartosz Żłobiński |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 06:38 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
Help with UDF to change mesh by external mesh generator | zou_mo | Fluent UDF and Scheme Programming | 1 | July 1, 2009 05:57 |
