Unstable solution with blueSolver
Old   November 10, 2015, 12:46
Default Unstable solution with blueSolver
Mike Lob
lpz_michele is on a distinguished road
Hi everyone!
I'm simulating a VAWT Darrieus Turbine using blueSolver. Following the tutorials everythings seems to be fine, but after starting the case, something goes wrong. Even if I'm using the std solutors of the case.
fvSolution
|  \\    /   O peration     | Version:  2.3.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
|  File created by CFD support s.r.o., Wed Oct 22 11:35:02 2014               |
|                    http://www.cdfsupport.com                                |
FoamFile
    version     2.3;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          GAMG;
        tolerance       1e-8;
        relTol          0.001;
        smoother        GaussSeidel;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 20;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    U
        solver          smoothSolver;
        nSweeps         2;
        tolerance       1e-20;
        relTol          0.1;
    k
        nSweeps         2;
        tolerance       1e-20;
        relTol          0.1;
    "(omega|epsilon)"
        nSweeps         2;
        tolerance       1e-20;
        relTol          0.1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    numberIterationsStator 1;
    numberIterationsRotor 1;
    UMax      500;
    pMin      pMin   [0 2 -2 0 0 0 0]    -1000;
    pMax      pMax   [0 2 -2 0 0 0 0]     1000;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        k               0.3;
        epsilon         0.3;
        omega           0.3;
fvSchemes
|  \\    /   O peration     | Version:  2.1.x                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default          none;
    div(phi,U)       bounded Gauss limitedLinearV 1.0;//Gauss linearUpwindV grad(U);
    div(phi,k)       bounded Gauss upwind;
    div(phi,omega)   bounded Gauss upwind;
    div(phi,epsilon) bounded Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
deltaT 0.0001
lpz_michele is offline   Reply With Quote
bluesolver, simple algorithm, steadystate
What's happening to my solution for lower relaxation factor casesam OpenFOAM Running, Solving & CFD 3 October 22, 2015 02:25
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 22:22
Hybrid mesh and unstable solution MOHAMMAD67 OpenFOAM 10 December 20, 2012 19:16
Analytic solution for 2D steady Euler equations jojo81 Main CFD Forum 0 October 15, 2012 13:05
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
