atmospheric boundary layer (ABL) - implementing wind direction |
November 4, 2015, 21:57 |
Robert Ong
Rep Power: 16 |
Hi all,
I'm having a lot of convergence issues when running simpleFoam using the ABL conditions with the wind direction. I've got three different mesh resolutions, all run without the wind direction i.e. flowDirection (1 0 0): the two finer ones (46 and 30m cells) converged, while the coarser mesh (12m cells) didn't. However, when running with the wind direction, for example east north-easterly (60deg), the simulations blew up (using all the three mesh resolutions). I implemented the wind direction by setting the flowDirection to (cos theta, sin 180-theta, 0), and since for this case all the angles are in positive values, I didn't switch inlet surfaces (inlet->outlet, and vice versa). Could anyone please advise on this? I'm sure this is something quite common, however, I can't seem to find the solution in this forum (maybe I miss or overlook something). Please let me know if you need some output files (e.g. checkMesh, log files, etc). Kind regards, Robert Last edited by rob3rt 0ng; November 4, 2015 at 22:03. Reason: proof read |
ERROR: Flow direction on the boundaries must not be tangential to the boundary. | turbomax | CFX | 3 | October 27, 2024 07:19 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Modeling of boundary layer wind profile in CFX 5 | Cuong NK | CFX | 7 | April 26, 2012 09:23 |
