simpleFoam crashes after 200 iterations
Old   November 3, 2015, 11:00
Default simpleFoam crashes after 200 iterations
Svensen is on a distinguished road
I run a steady-state simulation using simpleFoam. During first 200 iterations a solution converges quite well but suddenly after about 200 iterations a solution explodes... I've tried to play with relaxation coefficients but with no success.
Config files, log file and plot of residuals are attached in a zip file.
Maybe someone knows how to overcome this issue ??
Svensen is offline   Reply With Quote
Old   November 3, 2015, 14:42
sheaker's Avatar
Oskar
sheaker is on a distinguished road
Hello.
It looks like You got 1000 iterations for pressure. Maybe You need to change Initial residual?
sheaker is offline   Reply With Quote
Old   November 3, 2015, 15:44
Do you know how to do this ?
Old   November 3, 2015, 15:56
sheaker's Avatar
Oskar
Unfortunately I'm noob.
Maybe in file 0/p You can change internalField uniform to value that is close to Your calculation?
Old   November 4, 2015, 09:56
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
You have really strange numerical settings. nNonOrthogonalCorrectors 15 ... why did you do that?
Can you post "checkMesh" output?
In fvSolution:
solvers
    p
    solver           GAMG;
        tolerance        1e-12;
        relTol           0.001;
        smoother         DICGaussSeidel;
        nPreSweeps       0;
        nPostSweeps      1;
    nFinestSweeps    2;
    scaleCorrection  true;
    directSolveCoarsestLevel false;
        cacheAgglomeration on;
        agglomerator     faceAreaPair;
        nCellsInCoarsestLevel 500;
        mergeLevels      1;
        maxIter         100;
    U
        solver           smoothSolver;
        smoother         GaussSeidel;
        tolerance        1e-12;
        relTol           0.1;
        nSweeps          1;
        maxIter         100;
Set nNonOrthogonalCorrectors to 1;
Set relaxation for pressure to 0.3 and for velocity to 0.7.
In fvSolution:
Set gradScheme default to "Gauss linear".
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   November 5, 2015, 02:32
Vojtech Betak
betakv is on a distinguished road
Try to change outlet boundary condition for velocity from
type zeroGradient;
to
type inletOutlet;
inletValue uniform (0 0 0);
value $internalField;
betakv is offline   Reply With Quote
simplefoam not converged
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 19:17
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
