OpenFoam Airfoil simulation - replacing Fluent with OpenFOAM
Old   November 2, 2015, 06:50
Default OpenFoam Airfoil simulation - replacing Fluent with OpenFOAM
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Dear Foamers;
I am a recent user of OpenFoam and I transferred from Ansys Fluent to OpenFoam.
In fluent to solve either steady state or unsteady transient flow over an airfoil we use the far field boundary condition. As far as I know the free stream boundary condition is equivalent to this boundary condition in OpenFoam.
Furthermore, in fluent when we turn on the Farfield boundary and Ideal Gas condition: Energy equation must be solved.
I was wondering how can we set this up in OpenFoam? Is it necessary? Does it affect the accuracy of the solution?
Best Regards
Shereez
shereez234 is offline   Reply With Quote
Old   November 3, 2015, 04:54
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hi! In OpenFoam you don't "switch on" the energy equation like in Fluent, but you use a different solver (compressible solver). If you find a list of openFoam solvers you will see, that they are divided into the groups incompressible and compressible with steady-state and time-dependent, respectively. So you must pick the solver you need for your case and if you start it, it will tell you which files / specifications are missing.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
FLUENT or OpenFoam for Particle-surface intercation simulation? Amir1 Main CFD Forum 0 May 10, 2013 18:15
LSR (Land speed record) car simulation on FLUENT Maxime31850 FLUENT 2 May 1, 2013 12:15
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
