Get inlet flow angle for computing lift and drag coefficients
Old   October 30, 2015, 16:25
Default Get inlet flow angle for computing lift and drag coefficients
Jack
Jack001 is on a distinguished road
My problem should be simple: The lift of an airfoil is always in the direction normal to the free stream, and drag is in the opposite direction. I need a way of automatically getting the direction of the free stream velocity vector that is specified in myCase/0/U and read this into my system/controlDict file which computes the coefficients below:
myLiftDirection= (-sin(alpha) cos(alpha) 0 )
myDragDirection= (cos(alpha) sin(alpha) 0)
where alpha is obtained from the boundary condition file of the inlet velocity.
forceCoeffs
type forceCoeffs;
functionObjectLibs ("libforces.so");
patches (fixedWall);
// pName p;
// UName U;
rhoName rhoInf;
rhoInf 1000;
CofR (0 0 0);
liftDir myLiftDirection;
dragDir myDragDirection;
pitchAxis (0 0 0);
magUInf 0.05; // Free stream velocity
lRef 0.3; // Diameter of cylinder?
Aref 0.0707; // Ref. Area = cross sectional area?
outputControl timeStep;
outputInterval 1;
Jack001 is offline   Reply With Quote
controldict, force coefficients, get values
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Unsteady Flow past circular cylinder-Re=100 (fluctuating drag and lift co-efficients) Vino Main CFD Forum 0 April 10, 2014 10:39
Effect of turbulence of flow on lift and drag coefficients akku Main CFD Forum 1 April 9, 2013 02:12
Drag & lift coefficients for a velocity inlet BC tsi07 FLUENT 4 May 30, 2012 09:59
why lift coefficients don't converge at high angle of attacks? mingersai Main CFD Forum 13 January 13, 2012 16:38
