Density based turbo transonicSteadySRFFoam, sCO2 radial turbo?
Old   October 28, 2015, 20:21
Lightbulb Density based turbo transonicSteadySRFFoam, sCO2 radial turbo?
Janry
qjh888 is on a distinguished road
Hi all,
Recently I've tried to use OpenFOAM 3.0EX Density based turbo solver to carry out the supercritical CO_2 radial turbine simulation. However, when I try to operate the simulation, I've got many questions related to that.
--> The second step of my simulation has a big temperature drop, from 833.15K massively to 8.2K;
--> I've no idea how to implementation the Janaf specific heat for CO_2 into the thermoPhisicalPropeties.
I've attached my setting files and boundry, system files at this threads.
Thanks for your help!!!
Janry
29/10/2015
The thermoproperties:
| \\ / F ield | OpenFOAM Extend Project: Open Source CFD |
| \\ / O peration | Version: 1.6-ext |
| \\ / A nd | Web: www.extend-project.de |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object thermophysicalProperties;
// thermoType ePsiThermo<pureMixture<constTransport<specieThermo <eConstThermo<perfectGas>>>>>;
// mixture air 1 28.9 717.5 0 1.8e-05 0.7;
thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>;
// name, nMoles, mol weight, CP, Hf, mu, Pr;
mixture air 1 44.0095 1242.564 0 3.8e-05 0.7;
// mixture air 1 28.9 1004.5 0 0 0.7;
T.txt
U.txt
p.txt
controlDict.txt
fvSolution.txt
qjh888 is offline   Reply With Quote
Old   November 5, 2015, 00:30
Janry
On one reply me? Could anyone give me some solutions?
Thanks very much!
density_based_turbo, radial turbine, transonicsteadysrffoam
Current density visualisation (PEM fuel cell add-on module) pchoopanya FLUENT 10 August 21, 2023 15:33
Pressure based and Density based Solver Xobile Main CFD Forum 39 August 19, 2020 07:04
Density based compressible flow solution Ahmet Main CFD Forum 11 May 22, 2007 04:48
pressure and density based solvers sun Main CFD Forum 0 November 8, 2004 07:20
Density based codes? H.S.Muralidhara Main CFD Forum 3 May 28, 1999 07:29
