Boundary instabilities in thin fluid film using interFoam |
October 26, 2015, 17:38 |
Marķa Ignacia Bustos
Dear all,
I'm simulating an open channel flow of water with small depth using the interFoam (laminar) solver, but I'm having problems at the borders of the channel, it looks like the pressure is not behaving well, so it creates big inestable waves on the sides of the channel. I have tried changing the mesh, schemes, solvers and border conditions with no succes. I hope you could help me find what I'm doing wrong. The size of the channel is: 7 m length, 0.05 m wide and 0.012 m heigh. It has an inclination of 5.45°. The water initially has a 0.01 m depth and the other part is air. I attached the different fvSolution and p_rgh that I have tried, also blockMesh, fvScheme and screenshots of how the wave looks like. For the turbulenceProperties file, I have used laminar and LESModel (for the LESModel, I attached the LESProperties file). Also I have used different Courant numbers (between 0.2 and 0.5) to adjust the time step. I have tried with different cAlpha (between 0.25 and 1), with and without momentumPredictor and I have varied the tolerance, relTol, nOuterCorrectors, nCorrectors. In the fvScheme I have tried: -divSchemes div(phirb,alpha): Gauss interfaceCompression or Gauss linear -gradSchemes: Gauss linear or leastSquares alpha.water: boundaryField { entrada { type fixedValue; value uniform 1; } lateral-der { type zeroGradient; } lateral-iz { type zeroGradient; } salida { type inletOutlet; inletValue uniform 0; value uniform 0; } piso { type zeroGradient; } atmosfera { type inletOutlet; inletValue uniform 0; value uniform 0; } entrada-at { type fixedValue; value uniform 0; } } The initial velocity field it is (0 0.839937 -0.080137) in the water and (0 0 0) in the air. So the water moves with a velocity of 0.84 m/s paralel to the channel. U boundaryField { entrada { type flowRateInletVelocity; volumetricFlowRate constant 0.000421876; value uniform (0 0.839937 -0.080137); } lateral-der { type fixedValue; value uniform (0 0 0); } lateral-iz { type fixedValue; value uniform (0 0 0); } salida { type pressureInletOutletVelocity; value nonuniform List<vector> } piso { type fixedValue; value uniform (0 0 0); } atmosfera { type pressureInletOutletVelocity; value uniform (0 0 0); } entrada-at { type fixedValue; value uniform (0 0 0); } } |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
