fixedFluxPressure with PisoFoam
Old   October 26, 2015, 07:44
Default fixedFluxPressure with PisoFoam
Mohamed Elshahat Ouda
me.ouda is on a distinguished road
Hi all,
I have a problem of using fixedFluxPressure with pisoFoam solver and k-epsilon model which always return the below error at the beginning of simulation . When I change the pressure BC from fixedFluxPressure to zeroGradient the problem solved but I believe that fixedFluxPressure is much more appropriate for my case. Is there any problem regarding using fixedFluxPressure with pisoFoam?
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0.2 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0.2 0 0);
    outlet
        type            zeroGradient;
    lowerWall
        type            fixedValue;
        value           uniform (0 0 0);
    atmosphere
        type            zeroGradient;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            fixedFluxPressure;
    lowerWall
    atmosphere
        type            zeroGradient;
    outlet
    defaultFaces
        type            empty;
Starting time loop
Time = 0.05
Courant Number mean: 0.1 max: 0.1
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 3.10139e-06, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.999993, Final residual = 6.12323e-08, No Iterations 4
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  Foam::operator/(Foam::tmp<Foam::Field<double> > const&, Foam::UList<double> const&) at ??:?
#5  Foam::fixedFluxPressureFvPatchScalarField::updateCoeffs() at ??:?
#6  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::updateCoeffs() at ??:?
#7  Foam::fvMatrix<double>::fvMatrix(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:?
#8  Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacianUncorrected(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#9  Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#10  Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#11  Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#12
 at ??:?
#13  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#14
 at ??:?
Segmentation fault (core dumped)
me.ouda is offline   Reply With Quote
Old   October 27, 2015, 06:30
Any Idea why I can't use fixedFluxpressure with pisoFoam?
Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam mchurchf OpenFOAM 7 August 6, 2023 10:12
why pisoFoam take such a long time to converge? izna OpenFOAM Running, Solving & CFD 51 October 25, 2013 03:28
pisoFoam, pimpleFoam - Fluent user's questions RodriguezFatz OpenFOAM Running, Solving & CFD 0 September 4, 2013 05:26
rhoPimpleFoam with fixedFluxPressure + flowRateInletVelocity --> p diverges tatu OpenFOAM Running, Solving & CFD 1 March 21, 2013 16:10
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
