Axisymmetric flow problem in constricted pipe |
November 6, 2015, 06:43 |
#21 |
Philipp
Rep Power: 27 |
I know what DNS means. Your discretization scheme has a certain numerical diffusion. If this is not low enough you can't do any DNS or LES, basically your DNS becomes some kind of LES.
The skeleton ran out of shampoo in the shower. |
November 6, 2015, 06:52 |
#22 |
Kamil ÖZDEN
Rep Power: 13 |
My time integration scheme used in DNS works is IMEXOrder2 (ImplicitExplicitOrder2) and as far as I know it has a numerical diffusion low enough to solve the problem with DNS method. I've compared my DNS work with other DNS studies in the literature and our results are matched exactly.
Regards, Kamil |
November 6, 2015, 06:54 |
#23 |
Philipp
Rep Power: 27 |
And the spatial disrectization?
November 6, 2015, 07:08 |
#24 |
Kamil ÖZDEN
Rep Power: 13 |
Continuous Galerkin projection is used in Nektar++ for spatial discretisation of NS Equations.
Regards, Kamil |
November 6, 2015, 07:36 |
#25 |
Philipp
Rep Power: 27 |
Ok, and how fine was the mesh in the separation region?
November 6, 2015, 07:48 |
#26 |
Kamil ÖZDEN
Rep Power: 13 |
There are almost 2 million grid points at a region 5D after constriction.
Regards, Kamil |
August 16, 2023, 10:28 |
#27 |
Mike
Hi!
I try to simulate similar process - can you share geometry (blockMesh) ? |
Axisymmetric pipe flow example | Gowingeng | SU2 | 7 | March 29, 2017 04:27 |
3D Swirl flow in the pipe: convergence problem | Sachin U. Nimbalkar | FLUENT | 5 | December 22, 2016 01:34 |
simpleFoam problem validating 3D pipe flow | inf.vish | OpenFOAM Running, Solving & CFD | 6 | August 11, 2013 23:18 |
transient, impregnating flow problem | fgommer | FLUENT | 0 | February 29, 2012 16:10 |
simpleFoam convergence problems for pipe flow problem | Mike Graham | OpenFOAM Running, Solving & CFD | 0 | January 30, 2012 14:40 |
