Running distributed simpleFoam with 2 computers
Old   October 21, 2015, 15:46
Unhappy Running distributed simpleFoam with 2 computers
Cristhian Fuertes
crisefd is on a distinguished road
Hello everyone and excuse my english
I'm trying to run pitzDaily using distributed OpenFOAM, I've set up passwordless communication between the 2 nodes (using rsa), mirror disk sharing the pitzDaily folder (using nfs). However I get the following error after using command:
mpirun --hostfile machines -np 16 simpleFoam  /home/OpenFOAM/OpenFOAM/run/tutorials/incompressible/simpleFoam/pitzDaily -parallel > log&
Error:
[openfoam2:11635] [[44716,0],0] mca_oob_tcp_recv_handler: invalid message type: 12
My decomPoseParDict is:
numberOfSubdomains  16;
method          simple;
simpleCoeffs
    n           (4 2 2);
    delta       0.001;
distributed     yes;
roots
2(
"/home/OpenFOAM/OpenFOAM/run/tutorials/incompressible/mySimpleFoam/pitzDaily" //master node
"/mnt/nfs/pitzDaily" //slave node
Is the root to the master node's pitzDaily Case
and
Is the root to the slave node's pitzDaily
Is there something run with my setup ?
crisefd is offline   Reply With Quote
cluster computing, openfoam, parallel computation
OF 2.0.1 parallel running problems moser_r OpenFOAM Running, Solving & CFD 9 July 27, 2022 04:15
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
SimpleFoam solver running error Steinmann OpenFOAM Running, Solving & CFD 5 November 22, 2011 12:25
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
Problem with running FoamX in a distributed environment susana OpenFOAM Pre-Processing 1 March 28, 2007 18:11
