InterFoam - Validation for velocity profile in simple channel
Old   October 19, 2015, 07:42
Default InterFoam - Validation for velocity profile in simple channel
Mohamed Elshahat Ouda
me.ouda is on a distinguished road
Hi all,
I am trying to validate turbulence models in OpenFOAM in simple free surface steady flow. so I started with a simple channel of (20*1*2 m) with constant water height of 1.5 m and I imposed fixed velocity at inlet (0.2 m/sec for water and 0.0 for air) and I fixed the water level in the channel to make sure that the flow is steady and I set the initial water velocity to 0.2 m/sec. I used K-omega as turbulence model. The full case description can be seen at the attached files.
The problem that I didn't get the expected velocity profile, at first (up to 30 sec from the start) I have more or less constant velocity along the overall water depth (except at the bottom where no-slip condition was applied), 'see the attached picture'.
After 30 sec. the velocity profile started to oscillate.
Can any one tell me how can I validate the velocity profile in this case or should i make some modifications on my case setup before I think to validate it.
Also, should I compare the velocity profile from OpenFOAM directly with the experimental results or I need to do some statistical manipulations?
Thanks in advance,
Best regards
me.ouda is offline   Reply With Quote
printstack with interFoam solver for a simple droplet on a flat plate mebinitap OpenFOAM Running, Solving & CFD 19 October 5, 2013 11:13
CFX problem in ubuntu (linux) Vigneshramaero CFX 0 July 13, 2012 11:22
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 01:52
validation for densely packed channel flows shefali Main CFD Forum 1 February 8, 2011 04:35
Struggling with BCs for 'simple' interFoam case rassilon OpenFOAM Running, Solving & CFD 1 May 15, 2009 11:16
