problem when solve with simplefoam k-epsilon model
Old   October 5, 2015, 13:00
Default problem when solve with simplefoam k-epsilon model
hssn
hssnjfry is on a distinguished road
hi
when i try to solve my project after 10 time solving stoped and say like below
Time = 10
smoothSolver: Solving for Ux, Initial residual = 2.33919e-06, Final residual = 1.83275e-07, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 2.73437e-07, Final residual = 2.73437e-07, No Iterations 0
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#8 ? at ??:?
#9 ? at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? at ??:?
Floating point exception (core dumped)
why this happened and what i should to do?
hssnjfry is offline   Reply With Quote
Old   October 5, 2015, 13:02
Sravan Kumar
coolcrasher is on a distinguished road
I suppose there is not sufficient space in your drive to run your simulation or to write the results.
Make space and run the simulation again. Check if this works
coolcrasher is offline   Reply With Quote
Old   October 5, 2015, 13:46
hssn
i have 100 GB space but number of mesh is 32000 and ram is 3GB and my cpu is core 2duo but my procces is 2D.youn thinck my system is weak to run that?
Old   October 5, 2015, 14:06
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Usually this means diverging solution. What should you do? It depends on the result you would like to achieve.
Start with checkMesh. If mesh is OK, you can change GAMG solver for pressures equation to PCG in fvSolution. Then you can check you relaxation factors.
If these steps do not help, you can either describe your case, post case files here (tar.gz archive of case folder), or (if you not allowed to post case files) describe your case, post boundary conditions you are using, post checkMesh output.
(And in general this error has nothing to do with free disk space)
alexeym is offline   Reply With Quote
Old   October 5, 2015, 14:33
hssn
hi my file is here please check that
Old   October 5, 2015, 14:47
Alexey Matveichev
Yeah. Checked.
Old   October 5, 2015, 17:11
hssn
hi sorry you can download now here
Old   October 5, 2015, 18:14
Alexey Matveichev
And you really think this is better? You have plenty of choices: attache your small archive to the message here, put your case files on github, put your case files on bitbucket, put your files on Dropbox, put your files on Box, well there are A LOT of places where you can store legal content without all these pauses and banners.
Also as I said, you need to describe your case. Surely I can try to guess what you are trying to simulate, ask more questions, wait for the answers, ask even more questions. Yet it would be MUCH MORE easier if you describe the case yourself. Somehow you have missed "describe your case" clause in my answer.
File Type: png Capture d’écran 2015-10-05 à 23.06.28.png (105.4 KB, 14 views)
Old   October 6, 2015, 03:32
hssn
hi i fixed link
my describe case
i want to simulation a train 2D and calculation drag and turbulent parameter
my boundary is inlet: pached oulet: pached topbottom:wall train:wall frontback:empty
file in 0 folder is
for U
boundaryField
inlet
type fixedValue;
value uniform (15 0 0);
outlet
type zeroGradient;
topbottom
type fixedValue;
value uniform (0 0 0);
train
type fixedValue;
frontback
type empty;
for P
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
topbottom
type zeroGradient;
train
type zeroGradient;
frontback
type empty;
for nut
internalField uniform 0;
boundaryField
inlet
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
topbottom
type nutkWallFunction;
value uniform 0;
train
value uniform 0;
frontback
type empty;
for k
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.844;
boundaryField
inlet
type fixedValue;
value uniform 0.844;
outlet
type zeroGradient;
topbottom
type kqRWallFunction;
train
frontback
type empty;
for epsilon
boundaryField
inlet
type fixedValue;
value uniform 40.4;
outlet
type zeroGradient;
topbottom
type epsilonWallFunction;
value uniform 40.4;
train
value uniform 40.4;
frontback
type empty;
transportModel Newtonian;
nu nu [ 0 2 -1 0 0 0 0 ] 1e-05;
CrossPowerLawCoeffs
nu0 nu0 [ 0 2 -1 0 0 0 0 ] 1e-06;
nuInf nuInf [ 0 2 -1 0 0 0 0 ] 1e-06;
m m [ 0 0 1 0 0 0 0 ] 1;
n n [ 0 0 0 0 0 0 0 ] 1;
BirdCarreauCoeffs
k k [ 0 0 1 0 0 0 0 ] 0;
object controlDict;
application simpleFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 2000;
deltaT 1;
writeControl timeStep;
writeInterval 100;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwind grad(U);
div(phi,k) bounded Gauss linearUpwind grad(k);
div(phi,epsilon) bounded Gauss linearUpwind grad(epsilon);
div(phi,R) bounded Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) bounded Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver GAMG;
tolerance 1e-06;
relTol 1e-06;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
"(U|k|epsilon|R|nuTilda)"
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-06;
relTol 1e-6;
SIMPLE
nNonOrthogonalCorrectors 0;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.7;
epsilon 0.7;
R 0.7;
nuTilda 0.7;
Old   October 6, 2015, 08:50
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
You patch inlet and outlet? Are you sure you have 100% the same flux? How does that work? If there is just any small difference your simulation will blow up.
Also: How can your residuals be that low after just 10 iterations of SIMPLE?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   October 6, 2015, 10:15
hssn
hi
actually i want simulate a train in open air like airfoil
are you have better boundary condition for that ?i designed my shape in salome with dimension mm and meshed in that,is that need when export to openfoam consider translation scale or not ?
and i dont no how residuals be that low after just 10 iterations.i think maybe my epsilon is very high like 40 and k is 4 .
Old   October 6, 2015, 10:23
Philipp
What do you use for patching?
If you run checkMesh I think the physical dimensions of the grid are shown. You can see there if this is correct.
Old   October 6, 2015, 10:55
hssn
i use this order to convert mesh in salome to openfoam ideasUnvToFoam Mesh_1.unv then checkmesh and sayed ok
Old   October 6, 2015, 10:58
Philipp
I am not sure if that is an answer to my post...
If you run checkMesh it says "Overall domain bounding box..." in one line.
What does say inside the brackets ( xxxx ) ( xxxx)?
Old   October 6, 2015, 11:18
hssn
| \\ / O peration | Version: 2.4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.4.0-f0842aea0e77
Exec : checkMesh
Date : Oct 06 2015
Time : 17:48:10
Host : "hssn"
PID : 4255
Case : /home/hssn/Desktop/DNS/tryop
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM Warning :
From function checkMesh
in file db/Time/timeSelector.C at line 262
No time specified or available, selecting 'constant'
Create polyMesh for time = constant
Time = constant
Mesh stats
faces: 177246
internal faces: 145582
cells: 80707
faces per cell: 4
boundary patches: 5
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 80707
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
inlet 102 104 ok (non-closed singly connected)
topbottom 672 676 ok (non-closed singly connected)
frontback 18292 10386 ok (non-closed singly connected)
outlet 102 104 ok (non-closed singly connected)
train 12496 7054 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-13.064 -1.25179 0.003) (-11.564 -0.801795 0.013)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-1.12574e-19 -9.56173e-18 9.14914e-16) OK.
Max cell openness = 2.83931e-16 OK.
Max aspect ratio = 12.4271 OK.
Minimum face area = 3.85e-08. Maximum face area = 0.00252149. Face area magnitudes OK.
Min volume = 6.54628e-12. Max volume = 8.40498e-06. Total volume = 0.00660707. Cell volumes OK.
Mesh non-orthogonality Max: 75.4738 average: 20.8571
*Number of severely non-orthogonal (> 70 degrees) faces: 54.
Non-orthogonality check OK.
<<Writing 54 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 0.808257 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
Old   October 6, 2015, 11:22
Philipp
Now your brain comes into play!
The bounding box shows the size of your domain. From (x1, y1, z1) to (x2, y2, z2). So does that make sense that x goes from -13.064 to -11.564, thus having an x-length of about 1.5 meters?
Old   October 6, 2015, 11:47
hssn
yes my x length is 1.5 meter but i set salome to mm and i think that enough to recognized by openfoam.
i use transport scale to convert meter to mm but same error happened.i attached my filehere you can see that.i think my boundary is problem
Old   October 7, 2015, 02:45
Philipp
I don't understand you.
Old   October 7, 2015, 11:30
hssn
i fixed errore before.
i solved model by SpalartAllmaras but when used k-epsilon model residual in Iteration 8 for k and epsilon as below
smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 6.30323e-07, No Iterations 39
smoothSolver: Solving for k, Initial residual = 1, Final residual = 8.58102e-07, No Iterations 10
bounding k, min: -1.29847e+22 max: 1.98718e+33 average: 7.76856e+28
i want now way this happened? this is major question .
Old   October 8, 2015, 03:58
Philipp
I can't understand your english, sorry. Maybe someone else understands this.
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 10:39
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Air-lift model with hot gases and water. Time step problem. PauliusRap FLOW-3D 0 August 4, 2014 05:47
epsilon and K blowing up. sivakumar OpenFOAM Running, Solving & CFD 1 October 25, 2012 05:50
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 10:11
