Too much iterations for k, epsilon with Pointwise mesh
Like Tree5Likes
Old   October 13, 2015, 06:08
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Edit: I just made some pictures of your residuals over iteration / time. This looks ugly. I will post the picture.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   October 13, 2015, 06:26
Philipp
This is how the residuals of your case look like.
Old   October 13, 2015, 07:17
Jason
tigger is on a distinguished road
Philipp,
The solver I use is 'interFoam' and it is multiphase(water, air in this case) and unsteady solver.
interFoam use VOF(Volume of fluid) method to capture water interface(Freesurface).
In VOF, if I understands it correctly, solve 1 transport equation and 1 continuity equation that containing Alpha ( If Alpha is 0 : cell is gas phase(air), 1 : cell is full of water and value between 0 and 1 is interface..
I'll try under-relaxation factor on alpha!
The problem I solve is a floating square box with freestream..(Water flow past a square box)
Residuals in the picture you uploaded shows sudden rise of continuity..I don't know why but there should be something wrong..
by the way, which tool you used to draw residual plot? Did you used GNU plot?
If so, can I see the script you used?
Many thanks,
Jason
tigger is offline   Reply With Quote
Old   October 13, 2015, 07:21
Philipp
Yes it is gnuplot.
Copy the code to a file called "plotscript" in the same directory as your log file is.
You can run it with "gnuplot plotscript" during runtime, the plot will redone every 1 second.
If you want to plot a picture just delete the "#" in the first two lines and comment out the last lines "reread" and "pause 1".
Everything should be self-explanatory, but if you don't understand it, just ask...
#set terminal png size 800,600 enhanced font "Helvetica,12"
#set output 'output.png'
set logscale y
set title "Residuals"
set ylabel 'Residual'
set xlabel 'Iteration'
set key outside
set grid
set yrange[1e-14:10]
nCorrectors=3
nNonOrthogonalCorrectors=1
nCont = nCorrectors
nP = (nNonOrthogonalCorrectors+1)*nCont
nPSkip = nP-1
nContSkip = nCont-1
plot "< cat log | grep 'Solving for alpha.water' | cut -d' ' -f9 | tr -d ','" title 'alpha' with linespoints,\
"< cat log | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with linespoints,\
"< cat log | grep 'Solving for epsilon' | cut -d' ' -f9 | tr -d ','" title 'epsilon' with linespoints,\
"< cat log | grep 'time step continuity errors :' | cut -d' ' -f9 | tr -d ','" every nCont::nContSkip title 'continuity' with linespoints,\
"< cat log | grep 'Solving for p_rgh' | cut -d' ' -f9 | tr -d ','" every nP::nPSkip title 'p' with linespoints lc 8
pause 1
#xmax = GPVAL_DATA_X_MAX+2
#xmin = xmax-20
#set xrange [xmin:xmax]
reread
If you change the solver settings you must always also change the plotscript (OuterCorrections,...)
Frenk_T and Turin Turambar like this.
Old   October 13, 2015, 07:24
Philipp
The sudden rise comes from the next time step (every 15 iterations). This is quite normal for PIMPLE.
It is not good, that the residuals don't converge appreciably. Is there any change that you can run a steady state solution prior? Such as SIMPLE for initialization?
Old   October 13, 2015, 07:42
Jason
Philipp,
The scrip you gave me works well!
Thanks!
Well, I've never tried SIMPLE algorithm for initialization..
Old   October 16, 2015, 00:44
Wink
  #27
Elham
Elham is on a distinguished road
I had a very awfull number of iteration for p-rgh, around 190, and after changing relTol from 0 to 0.001 it is great, around 10.
Thanks for your advice.
tigger likes this.
Elham is offline   Reply With Quote
Old   October 16, 2015, 03:17
Philipp
Great, but does it converge now?
Old   October 16, 2015, 03:52
Elham
Unfortunately, I didn't pay attention to the second attempt for solving p-rgh which is still have high No iteration.
MULES: Solving for alpha.water
Phase-1 volume fraction = 2.111971e-05 Min(alpha1) = 0 Max(alpha1) = 0.9974017
GAMG: Solving for p_rgh, Initial residual = 0.05853901, Final residual = 5.498377e-05, No Iterations 6
time step continuity errors : sum local = 3.274181e-09, global = 1.346159e-14, cumulative = -6.08748e-09
GAMG: Solving for p_rgh, Initial residual = 0.0001254836, Final residual = 9.72051e-07, No Iterations 80
time step continuity errors : sum local = 5.814538e-11, global = 5.793274e-17, cumulative = -6.08748e-09
ExecutionTime = 80707.64 s ClockTime = 81027 s
Old   October 16, 2015, 04:17
Philipp
You could try a different smoother for the GAMG.
p
        solver           GAMG;
        tolerance        1e-12;
        relTol           0.1;
        smoother         DICGaussSeidel;
        nPreSweeps       0;
        nPostSweeps      1;
        nFinestSweeps    2;
        scaleCorrection  true;
        directSolveCoarsestLevel false;
        cacheAgglomeration on;
        agglomerator     faceAreaPair;
        nCellsInCoarsestLevel 500;
        mergeLevels      1;
        maxIter         100;
I meant the PIMPLE algorithm, not the linear solvers, sorry. Does PIMPLE converge now?
convergence, diverge, interfoam
a problem with convergence in buoyantSimpleFoam skuznet OpenFOAM Running, Solving & CFD 6 November 15, 2017 13:12
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
should Courant number always be kept below 1? wc34071209 OpenFOAM Running, Solving & CFD 16 March 9, 2014 20:31
rhoSimplecFoam Mach0.8 no pressure values CFDnewbie147 OpenFOAM Running, Solving & CFD 16 November 23, 2013 06:58
