pimpleDyMFoam won't restart from latestTime
Old   September 25, 2015, 13:47
Default pimpleDyMFoam won't restart from latestTime
Adam
xixchubbsxix is on a distinguished road
I am currently running simulation of rotating airfoils using the cyclicAMI Mesh. For previous runs (different mesh) I had no problem restarting the run if it blew or ran out of time from the latestTime. I then changed the number of airfoils from 3 to 2 in my mesh while keeping every other parameter the same. Now when I try to restart the run I get this error:
pimpleDyMFoam
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.4.0-dcea1e13ff76
Exec   : pimpleDyMFoam
Date   : Sep 25 2015
Time   : 12:41:40
Host   : "brlogin1"
PID    : 95147
Case   : /work/blueridge/adamen92/aoe5984/RAS_sepfoils/2foils
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 2e-05
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone rotating-cells
PIMPLE: Operating solver in PISO mode
Reading field p
Reading field U
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/apps/gcc4_7/openmpi1_6/OpenFOAM/2.4.0/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/apps/gcc4_7/openmpi1_6/OpenFOAM/2.4.0/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  ? in "/lib64/libc.so.6"
#3  Foam::surfaceInterpolation::makeWeights() const in "/opt/apps/gcc4_7/openmpi1_6/OpenFOAM/2.4.0/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4  Foam::surfaceInterpolation::weights() const in "/opt/apps/gcc4_7/openmpi1_6/OpenFOAM/2.4.0/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5  Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::linearInterpolate<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/apps/gcc4_7/openmpi1_6/OpenFOAM/2.4.0/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/bin/pimpleDyMFoam"
#6  ? in "/opt/apps/gcc4_7/openmpi1_6/OpenFOAM/2.4.0/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/bin/pimpleDyMFoam"
#7  __libc_start_main in "/lib64/libc.so.6"
#8  ? in "/opt/apps/gcc4_7/openmpi1_6/OpenFOAM/2.4.0/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/bin/pimpleDyMFoam"
Floating point exception
I tried to run it both it serial and parallel and the same error happens. I tried both refine and coarsen my mesh and change the number of points on the AMI boundary. Since everything else is consistent from older runs in the 0/ system/ and constant/ directories except the mesh I just assumed that had to be the problem.
Can someone help me try to figure out what these errors mean so I can try to see where the error is actually occurring, or if anyone has run into a similar problem have any suggestions for me????
-Adam
xixchubbsxix is offline   Reply With Quote
Old   September 30, 2015, 06:26
Sravan Kumar
coolcrasher is on a distinguished road
I have faced similar problem couple of times.
I guess it is the problem with your memory where openFoam is installed. I guess there is no sufficient space to write the files further.
I usually delete my previous cases and then make some free space and I run the case again the case works fine.
I am not sure if it works, but give it a try
coolcrasher is offline   Reply With Quote
amicyclic, cyclicami, floating point exception, pimpledymfoam, restart solution
Savonius pimpleDyMFoam vitokad OpenFOAM Pre-Processing 10 September 16, 2014 10:30
pimpleDyMFoam solid body rotation restart issue bennn OpenFOAM Running, Solving & CFD 0 November 28, 2013 18:16
Problem with multiframe restart of two-way fsi coupled problem Dimone CFX 26 December 20, 2011 11:10
DieselFoam does not restart from latestTime lord_kossity OpenFOAM Bugs 8 February 21, 2009 14:54
v4 restart bug optima prime Siemens 3 February 2, 2009 23:51
