Wind Turbine blade in 120° wedge - boundary conditions
Old   September 23, 2015, 13:02
Default Wind Turbine blade in 120° wedge - boundary conditions
Fabrizio
Fcamp is on a distinguished road
I'm trying to simulate the flow around a wind turbine blade with the SRF approach, using the k-epsilon model.
The rotational speed of the wind turbine is 12 rpm, while the air velocity is set to 10 m/s.
My mesh seems to be acceptable.
However, I'm having trouble with the boundary conditions implementation on the farfieldPatch. The ones I currently have are the following:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      Urel;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 10 0);
boundaryField
    inlet
        type            SRFVelocity;
        inletValue      uniform (0 10 0);
        relative        no;
        value           uniform (0 0 0);
    outlet
        type            zeroGradient;
   farfieldPatch
/*        type            slip;*/
/*        type            SRFFreestreamVelocity;*/
/*        UInf            (0 10 0);*/
/*        type            zeroGradient;*/
        type            SRFVelocity;
        relative        no;
    plane1Patch
        type            cyclicAMI;
    plane2Patch
        type            cyclicAMI;
    bladePatch
        type            fixedValue;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    farfieldPatch
        type            zeroGradient;
    plane1Patch
        type            cyclicAMI;
    plane2Patch
        type            cyclicAMI;
    bladePatch
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      k;
internalField   uniform 200; // = (3/2)*(U*I)^2 //0.375
boundaryField
    inlet
        type            fixedValue;
        value           $internalField;
/*        type            turbulentIntensityKineticEnergyInlet;*/
/*        intensity       0.05; */
/*        value           uniform 1; //placeholder*/
    outlet
        type            zeroGradient;
    farfieldPatch
        type            slip;
    plane1Patch
        type            cyclicAMI;
    plane2Patch
        type            cyclicAMI;
    bladePatch
        type            kqRWallFunction;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 3500; // = Cmu^(3/4)*k^(3/2)/l //0.2695
boundaryField
    inlet
        type            fixedValue;
/*        type            turbulentMixingLengthDissipationRateInlet;*/
/*        mixingLength    0.14;*/
    outlet
        type            zeroGradient;
    farfieldPatch
        type            slip;
    plane1Patch
        type            cyclicAMI;
    plane2Patch
        type            cyclicAMI;
    bladePatch
        type            epsilonWallFunction;
        U               Urel;
Regarding Urel, the boundary conditions on farfieldPatch slip, SRFVelocity and zeroGradient all give me the same weird discontinuity you can see in the picture.
SRFFreestreamVelocity (what does it do?) makes my solution diverge.
I also have doubts for the values of k and epsilon: using the suggested formulas ( http://www.cfd-online.com/Wiki/Turbu...ary_conditions ) I obtain the commented values. However, the solution diverges using those values, and after many trial and errors I got to very high final values. Is it possible that those are correct? Do I have to use the relative wind speed or the absolute wind speed to calculate them?
Thank you in advance for any suggestions!
Fcamp is offline   Reply With Quote
Old   December 2, 2019, 07:47
mostafa kamal
mostafa kamal is on a distinguished road
i think you should use simpleFoam with MRF option , i think the solver is more stable
mostafa kamal is offline   Reply With Quote
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Radiation interface hinca CFX 15 January 26, 2014 18:11
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 03:33
