mixerVesselAMI2D, propeller -- fvSolution file doubts
Old   September 16, 2015, 11:52
Default mixerVesselAMI2D, propeller -- fvSolution file doubts
Sravan Kumar
coolcrasher is on a distinguished road
Hi
I am new to openFoam and presently working to simulate the centrifugal pump in a transient way as in mixervesselAMI2D, propeller.
However I have some doubts regarding settings in mixervessleAMI2D, propeller fvSolutions file.
Following are my questions
1) What is cellMotionUx specifed ? What is it purpose and why is it defined only for Ux and not for Uy ??
cellMotionUx
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-08;
        relTol          0;
2) What is the purpose of correctPhi in PIMPLE settings ?? when should it be used. Also the use of pRefCell and pRefValue ?? When do you need to specify them ?
PIMPLE
    correctPhi          yes;
    nOuterCorrectors    2;
    nCorrectors         1;
    nNonOrthogonalCorrectors 0;
    pRefCell            0;
    pRefValue           0;
3) What is cache ? when it should be used ?
cache
    grad(U);
4) By default pressure is solved using GAMG solver which is a multigrid solver. Can we replace it with some PCG solver ( given in userguide ). Or is it like we have to use GAMG only with pimpleDyMFoam.
Please give me some information so that make a fvSolutions file for my simulation.
Any suggestions or information would be helpful.
Thanks in Advance
coolcrasher is offline   Reply With Quote
Old   September 25, 2015, 16:58
Sravan Kumar
Any help guys ??????
Old   February 5, 2018, 09:07
Default mixer
Przemek Nosal
PrzemekN is on a distinguished road
did you run the mixerVesselAMI2D?? Could you send me the commands?
Thanks Przemek
PrzemekN is offline   Reply With Quote
ami, fvsolution, pimpledymfoam, transient
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 22:03
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
