Add diffunding concentration into LES simulation |
September 10, 2015, 14:47 |
Pablo Ernesto Romero
Hi everybody,
I am running transient LES simulations with pisoFoam (Smagorinsky model) and a Reynolds number of about 1000. I am trying to add on some nodes (or a specified surface) a concentration that is diffunding into the fluid and transported with the flow. I am interested in how this concentration gets transported through the geometry. How must I proceed if want to add any concentration in some cells of the field and just let it diffuse in the fluid? Thx Pablo |
September 10, 2015, 18:08 |
If the source of concentration is on a boundary cells, define the cells with a set of concentration using a patch on the surface. And then use the patch name for you concentration inlet boundary condition.
Have a look at the following tutorial to add a transport equation to icoFoam: https://openfoamwiki.net/index.php/H...ure_to_icoFoam http://www.tfd.chalmers.se/~hani/kur...ngTutorial.pdf |
September 12, 2015, 15:26 |
Thx a lot rkc.cfd! I followed the tutorial and a simulation is running!
What if the source of concentration is NOT on boundary cells. I want to select some cells of the domain.. How can I do that? |
September 12, 2015, 19:50 |
I have no clue how to do it. I suppose you can use the baffle option, but I have not used it though. I hope some one has done that in the forum and I am also curios about it. About baffles:
https://openfoamwiki.net/index.php/CreateBaffles |
les, pisofoam, smagorinsky, transient |
add concentration | libia87 | OpenFOAM | 5 | May 25, 2018 13:12 |
LES Simulation of 5-to-1 rectangular prism | tung.nguyen | OpenFOAM | 1 | July 2, 2014 05:56 |
Variable of concentration for multiphase simulation | syens | CFX | 0 | February 21, 2012 10:30 |
continue LES simulation after it stopped | holand_us | OpenFOAM | 9 | April 5, 2010 13:52 |
Residuals for LES Simulation | Forrest | FLUENT | 0 | March 12, 2009 16:24 |
