Problem with gravity in chtMultiRegionSimpleFoam |
September 10, 2015, 03:41 |
Vincent RIVOLA
Rep Power: 18 |
Dear all,
I need to simulate the heat transfer around an object at a certain altitude where the pressure is about 5000Pa. The problem is that since my object is quite big, I also have a large domain which is a sphere of 2km radius. I want my fluid to be driven by the heat transfer from the object wall to the fluid, so natural convection. The problem is that my simulation crash after one or two time step. If I scale down the whole domain to a sphere of about 2m radius, the simulation is working fine. The difference is mainly the large gradients in pressure that are present in the large domain (due to gravity) and which are much smaller in the small domain. So I tried to initialize the p field with the expected pressure before starting the simulation, but it does not solve the problem. Does someone have an idea on how to solve this issue? Here are the boundary conditions I use: - p: Code:
internalField uniform 5000; boundaryField { object { type calculated; value $internalField; } farfield { type calculated; value $internalField; } } Code:
internalField uniform 5000; boundaryField { object { type fixedFluxPressure; value uniform 5000; } farfield { type fixedValue; value uniform 5000; } } Code:
internalField uniform 220; boundaryField { object { type fixedValue; value uniform 290; } farfield { type inletOutlet; inletValue uniform 220; value uniform 220; } } Code:
internalField uniform (0 0 0); boundaryField { object { type fixedValue; value uniform (0 0 0); } farfield { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } } |
September 14, 2015, 05:33 |
Vincent RIVOLA
Rep Power: 18 |
Nobody has an idea on how to solve this issue?
Do you need more information? I forgot to say that the mesh is ok according to chechMesh. |
Two Phase Darcy flow with gravity -> problem | Cyp | OpenFOAM Programming & Development | 0 | November 17, 2010 08:58 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
gravity problem. | vidhuresh | FLUENT | 6 | October 31, 2005 01:59 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 15:52 |
