September 8, 2015, 09:20 |
mapFields - C7H16 loss
I am working on sprayEngineFoam in OF 2.3. I have a simple engine geometry with liner, piston, chamber_roof and intake port with no valves. I have a completed case from 80° to 180° with injection at 142°, and then i tried to map the fields to a new geometry for the compression stroke (i.e) without any intake ports. The mapping process is successfull, all the fields looks fine, but there seems to be a loss only in C7H16, N2, O2, H20 at 181°. I have attached both the pictures, could somebody please help me. |
c7h16, mapfileds, sprayenginefoam |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Strange random behaviour of mapFields | blaise | OpenFOAM Pre-Processing | 0 | November 3, 2014 09:37 |
Convective heat loss out of a solar receiver construction | Lionel Trébuchon | CFX | 10 | April 6, 2014 20:25 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
loss calculation in simulation of turbomachines | playmaster | Main CFD Forum | 0 | August 21, 2010 05:59 |
