icoFoam floating point exception (8)
Old   September 6, 2015, 19:15
Default icoFoam floating point exception (8)
Lei Zhao
leizhao512 is on a distinguished road
Hi, everyone. I was quite new to openFoam. I am simulating a cylindrical channel with a spiral spacer. It is a laminar flow since the inlet flow velocity is 2e-5m/s and the Re is 1.2. I initially was using Fluent and it the results were good. Then I want to use icoFoam. The mesh I was using in openFoam was converted from a Fluent mesh, and by checking mesh, it said OK. I am using the time step of 10s, which is exactly same with what I was using in Fluent. However, the solution always diverge and gave me an error of "floating point exception (8)". Besides, the Courant number kept increasing. Can anybody help me with this?
Thank you.
The error message is like this:
in "/opt/apps/gcc4_5/openmpi1_6/OpenFOAM/2.3.0/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #1 Foam::sigFpe::sigHandler(int) in "/opt/apps/gcc4_5/openmpi1_6/OpenFOAM/2.3.0/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #2 in "/lib64/libc.so.6"
[1] #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/opt/apps/gcc4_5/openmpi1_6/OpenFOAM/2.3.0/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const in "/opt/apps/gcc4_5/openmpi1_6/OpenFOAM/2.3.0/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/apps/gcc4_5/openmpi1_6/OpenFOAM/2.3.0/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #6
[1] in "/opt/apps/gcc4_5/openmpi1_6/OpenFOAM/2.3.0/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/icoFoam"
[1] #7
[1] #8
[1] #9
[1] #10 __libc_start_main in "/lib64/libc.so.6"
[1] #11
[hs122:14272] *** Process received signal ***
[hs122:14272] Signal: Floating point exception (8)
[hs122:14272] Signal code: (-6)
[hs122:14272] Failing at address: 0x1ba912000037c0
[hs122:14272] [ 0] /lib64/libc.so.6(+0x32920) [0x7f1aef331920]
[hs122:14272] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x7f1aef3318a5]
[hs122:14272] [ 2] /lib64/libc.so.6(+0x32920) [0x7f1aef331920]
[hs122:14272] [ 3] /opt/apps/gcc4_5/openmpi1_6/OpenFOAM/2.3.0/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam22symGaussSeidelSmoother6sm oothERKNS_4wordERNS_5FieldIdEERKNS_9lduMatrixERKS5 _RKNS_10FieldFieldIS4_dEERKNS_8UPtrListIKNS_17lduI nterfaceFieldEEEhi+0x512) [0x7f1af03928d2]
[hs122:14272] [ 4] /opt/apps/gcc4_5/openmpi1_6/OpenFOAM/2.3.0/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam22symGaussSeidelSmoother6s moothERNS_5FieldIdEERKS2_hi+0x2d) [0x7f1af039303d]
[hs122:14272] [ 5] /opt/apps/gcc4_5/openmpi1_6/OpenFOAM/2.3.0/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam12smoothSolver5solveERNS_5 FieldIdEERKS2_h+0x412) [0x7f1af0388b32]
[hs122:14272] [ 6] icoFoam() [0x43bfa5]
[hs122:14272] [ 7] icoFoam() [0x43e0aa]
[hs122:14272] [ 8] icoFoam() [0x43e3e0]
[hs122:14272] [ 9] icoFoam() [0x41d97c]
[hs122:14272] [10] /lib64/libc.so.6(__libc_start_main+0xfd) [0x7f1aef31dcdd]
[hs122:14272] [11] icoFoam() [0x4196b9]
[hs122:14272] *** End of error message ***
mpirun noticed that process rank 1 with PID 14272 on node hs122 exited on signal 8 (Floating point exception).
usage: kill [ -s signal | -p ] [ -a ] pid ...
kill -l [ signal ]
leizhao512 is offline   Reply With Quote
Old   September 6, 2015, 19:18
Default case file
Lei Zhao
I also uploaded my case file without mesh file as the mesh file is too large.
The log file is:
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 10
Courant Number mean: 0.000107184 max: 0.266238
smoothSolver: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 9.04463e-09, No Iterations 147
smoothSolver: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG: Solving for p, Initial residual = 1, Final residual = 25.9149, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.0840296, Final residual = 0.0010788, No Iterations 1001
time step continuity errors : sum local = 0.00167782, global = -0.000131827, cumulative = -0.000131827
DICPCG: Solving for p, Initial residual = 0.0516744, Final residual = 9.79542e-05, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.0153046, Final residual = 6.87564e-05, No Iterations 1001
time step continuity errors : sum local = 0.000188136, global = -3.53417e-06, cumulative = -0.000135361
ExecutionTime = 122.56 s ClockTime = 123 s
Time = 20
Courant Number mean: 0.721766 max: 6.47043
smoothSolver: Solving for Ux, Initial residual = 0.694741, Final residual = 9.63998e-09, No Iterations 239
smoothSolver: Solving for Uy, Initial residual = 0.608072, Final residual = 9.55807e-09, No Iterations 254
smoothSolver: Solving for Uz, Initial residual = 0.698027, Final residual = 9.68723e-09, No Iterations 244
DICPCG: Solving for p, Initial residual = 0.120674, Final residual = 0.0317097, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.136847, Final residual = 0.00306148, No Iterations 1001
time step continuity errors : sum local = 0.042808, global = 0.0014139, cumulative = 0.00127853
DICPCG: Solving for p, Initial residual = 0.0569325, Final residual = 0.000320575, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.0201781, Final residual = 0.000587244, No Iterations 1001
time step continuity errors : sum local = 0.0180552, global = 0.000196775, cumulative = 0.00147531
ExecutionTime = 250.23 s ClockTime = 251 s
Time = 30
Courant Number mean: 2.44691 max: 124.162
smoothSolver: Solving for Ux, Initial residual = 0.75502, Final residual = 9.61463e-09, No Iterations 248
smoothSolver: Solving for Uy, Initial residual = 0.634171, Final residual = 9.97674e-09, No Iterations 266
smoothSolver: Solving for Uz, Initial residual = 0.759349, Final residual = 9.81736e-09, No Iterations 248
DICPCG: Solving for p, Initial residual = 0.135442, Final residual = 0.0361863, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.154305, Final residual = 0.00439654, No Iterations 1001
time step continuity errors : sum local = 0.757218, global = -0.0137298, cumulative = -0.0122545
DICPCG: Solving for p, Initial residual = 0.0564087, Final residual = 0.000233005, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.0271797, Final residual = 0.000498899, No Iterations 1001
time step continuity errors : sum local = 0.194416, global = 0.00252102, cumulative = -0.00973351
ExecutionTime = 384.17 s ClockTime = 385 s
Time = 40
Courant Number mean: 28.8262 max: 1431.65
smoothSolver: Solving for Ux, Initial residual = 0.660078, Final residual = 9.66353e-09, No Iterations 308
smoothSolver: Solving for Uy, Initial residual = 0.55, Final residual = 9.62978e-09, No Iterations 357
smoothSolver: Solving for Uz, Initial residual = 0.663699, Final residual = 9.85606e-09, No Iterations 298
DICPCG: Solving for p, Initial residual = 0.174997, Final residual = 0.0255697, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.113939, Final residual = 0.00314605, No Iterations 1001
time step continuity errors : sum local = 7.08733, global = 0.208589, cumulative = 0.198855
DICPCG: Solving for p, Initial residual = 0.0402492, Final residual = 0.000105796, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.0286548, Final residual = 0.000240382, No Iterations 1001
time step continuity errors : sum local = 1.11688, global = 0.00996845, cumulative = 0.208824
ExecutionTime = 525.73 s ClockTime = 527 s
Time = 50
Courant Number mean: 340.81 max: 12310.1
smoothSolver: Solving for Ux, Initial residual = 0.595993, Final residual = 9.93393e-09, No Iterations 827
smoothSolver: Solving for Uy, Initial residual = 0.605277, Final residual = 1.84456e-08, No Iterations 1000
smoothSolver: Solving for Uz, Initial residual = 0.596082, Final residual = 9.99107e-09, No Iterations 824
DICPCG: Solving for p, Initial residual = 0.147091, Final residual = 0.01536, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.180302, Final residual = 0.00397467, No Iterations 1001
time step continuity errors : sum local = 41.5979, global = -1.37837, cumulative = -1.16955
DICPCG: Solving for p, Initial residual = 0.0424793, Final residual = 0.000639773, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.0471108, Final residual = 0.00111893, No Iterations 1001
time step continuity errors : sum local = 34.9303, global = -0.74496, cumulative = -1.91451
ExecutionTime = 728.05 s ClockTime = 730 s
Time = 60
Courant Number mean: 3151.15 max: 124948
Old   September 7, 2015, 00:28
Cyp
Cyprien
Cyp is on a distinguished road
what if you reduce your time step?
Cyp is offline   Reply With Quote
Old   September 7, 2015, 10:40
Lei Zhao
I was using time step of 10 in Fluent, and the solution converged quickly. I also tried to shrink the time step to 1s in openFoam, but it didn't work. Is there any problem with my case setup, the fvscheme?
Old   September 7, 2015, 13:27
Cyp
Cyprien
What if you reduce the time step even lower ? I guess in Fluent you have an adaptative time step, something you don't have with icoFoam, so probably when you say 10s time step in Fluent, it is not exactly the time stepd used during simulation.
If the error persists, I will say something is wrong in your boundary condition set up.
Old   September 10, 2015, 12:36
Lei Zhao
I was using fixed time step in Fluent.
Then I tried to use simpleFoam to simulate the case because I have proved that it was steady state case using Fluent. The case could be converged in the first 400 iterations. However, if I just copy the solution of simpleFoam to icoFoam as the initial condition, and the schemes and linear solvers are same, the icoFoam case will still be divergent in 100 time steps.
Old   September 10, 2015, 16:33
Troy Snyder
tas38 is on a distinguished road
You need to restrict the Courant number in icoFoam. You can do this as suggested by decreasing the time step manually, or you can implement an adjustable time step with a maximum specified Courant number. You can add the following to the controlDict file...
adjustTimeStep true;
maxCo 1.0;
Depending on your case, you may have to drop maxCo even lower.
tas38 is offline   Reply With Quote
Old   November 1, 2018, 12:43
itsme_kit is on a distinguished road
Hi Lei
Have you figured out what kind of problems could trigger "floating point exception (8)"?
I had the same problem recently.
I don't think it's about dividing by 0.
Many thanks
Thank you.
itsme_kit is offline   Reply With Quote
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 20:28
Inlet Velocity Profile BC - Floating Point exception during solution initialization Janshi STAR-CCM+ 4 March 14, 2012 11:21
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 17:23
Pipe flow in settlingFoam floating point exception jochemvandenbosch OpenFOAM Running, Solving & CFD 4 February 16, 2012 04:24
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 05:59
