Lagragian particles get the right force but wrong velocity
Old   August 31, 2015, 11:27
Default Lagragian particles get the right force but wrong velocity
Kabra is on a distinguished road
Hi all,
I use lagrangian particles with swak4foam and implemented an additionional force the way it's described in this thread:
http://www.cfd-online.com/Forums/ope...gian-data.html
I can run the simulation and first everything works well as the force applied to the particle is exactly what one would expect. The problem now is that the velocity of the particle is much higher than expected although all other values seem to fit (Force, volume, density).
I have no other forces activated than the one I implemented, thus I can assume that nothing else affects the particle.
When I check the output in my logfile I can see that in one step the force on the particle gets calculated up to 150 (onehundredfifty) times. I understand that the lagrangian particles use several stepfractions in their calculations, however this shoudn't usually lead to any problems.
Does anyone know what might be the problem or has experienced something similar?
Kabra is offline   Reply With Quote
lagrange particle, lagrangian, swak4foam, timesteps, velocity
Wrong initial particle velocity in my air-blast-atomizer problem...? gaghane FLUENT 0 December 4, 2014 07:57
velocity inlet and ideal gas simultaneously-what's wrong? preetam69 FLUENT 0 September 28, 2013 05:51
Force between particles and the floor shibata OpenFOAM 0 September 5, 2011 12:14
Compare 2D axi-symmetric and 3D. Is OpenFOAM calculate the velocity wrong? RalphS OpenFOAM 6 November 13, 2010 21:51
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
