multiphase cylindrical flow through porous medium; BC
Old   August 31, 2015, 09:55
Question multiphase cylindrical flow through porous medium; BC
a.b.mkarzel
adrianabm is on a distinguished road
hello,
I apologize in advance for my long post ;
after having researched this forum for threads that could be helpful I have decided to start this new thread. if you feel this has already been addressed elsewhere please redirect me.
there is a lot of scattered helpful literature but unfortunately, there's always a missing link somewhere with what i'm trying to do, especially given that i'm using many things at the same time (snappyhexmesh, porosity, multiphase, cylindrical CS,...) which is what brought me to writing this post.
I am new to openfoam so I may have a few 'obvious' mistakes, any guidance would be appreciated. I'm running on version 2.4, here's my case :
I'm trying to simulate the equivalent of a 'dam break' case but in a cylinder, containing a porous zone (so not entirely porous, picture below). the geometry is a cylinder of radius 0.005m, and height 0.03m. excluding the inlet and outlet patches (blue), the longitudinal direction of the tube is split into 3 parts of length 10 mm, the bottom and top parts (red) form the patch I call "main", and the middle green part is my "porous" patch
[[ a somewhat similar problem here : http://www.cfdandco.com/resources/JR...sInter_v11.pdf
but it is cartesian and doesn't use snappyhexmesh ]]
before I discuss the 2-phase aspect of my case, let me clarify how I implement the porous zone.
I had looked it up and noticed that a few methods were available, either using fvOptions (the newer method) or by defining a cellZone and using porosityProperties, which is what I opted for. my steps are as follows :
1) blockMesh
2) $ setSet
$ cellSet [name of cells] new cylinderToCell (0 0 0.01) (0 0 0.02) 0.005
$ cellZoneSet [name of cellZone] new setTocellZone [name of cells]
3) surfaceFeatureExtract -> snappyHexMesh
my result is the second picture containing the mesh.
the porous zone is supposed to model a large amount of small unidirectional channels, so I consider it as an anisotropic porous zone, the fluid has to go along Z, so I just put a much higher resistance in X and Y. (r, theta)
I'm not sure if by locally defining a cylindrical CS as seen below, i've accurately represented my porous medium or not... here's what i've read about it (http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2008/HaukurElvarHafsteinsson/haukurReport.pdf)
    class       dictionary;
    location    "constant";
    object      porosityProperties;
porosity1
    type            DarcyForchheimer;
    active          yes;
    cellZone        porosity;
    DarcyForchheimerCoeffs
    mu mu;
        d   d [0 -2 0 0 0 0 0] (2e10 2e10 3.96221e5);
        f   f [0 -1 0 0 0 0 0] (0 0 0);
        coordinateSystem
            type    cartesian;
            origin  (0 0 0);
            coordinateRotation
                type    localAxesRotation;
                e3      (0 0 1);
        //type    axesRotation;
        //e1    (0 0 1);
               // e2    (0 1 0);
3rd picture : I then define my multiphase initialization in setFieldsDict where I define an 8mm long cylinder of oil, also 5mm radius, in the "main" patch near the "inlet". It will later be subject to the gravitational acceleration "g" in the Y direction and will consequently fill the tube just like the Cartesian dam break example (in red), pushing around the air that initially fills the rest of the tube (in blue).
to solve this case, i'm using the porousInterFoam solver and after finally managing to get it running, my solution starts to diverge as soon as the interface reaches the inlet of the porous zone (cf. picture below).
right now, my guess is that my boundary conditions for the oil phase are not correct.. but the problem could also be due to a badly defined porous zone or a bad choice of solvers.. i don't know if anyone has already had a similar experience, in any case, any help or hints as to how I can trace the error causing the crash interface><porouszone would be appreciated.
thank you
[here are the BCs I tried for the oil phase
    class       volScalarField;
    object      alpha.oil;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            zeroGradient;
    main
        type            inletOutlet;
        inletValue      uniform 0; //was 1
        value           uniform 0; //was 1
    porous
      type        zeroGradient;
      //  type            inletOutlet;
      //  inletValue      uniform 0; //was 1
      //  value           uniform 0; //was 1
    defaultFaces
        type            empty;
adrianabm is offline   Reply With Quote
Old   September 7, 2015, 11:37
a.b.mkarzel
hello,
i'm happy to say that personally, the problem of the divergence was due to a slighlty non-smooth/unaligned circular edge linking the main part to the porous part. i'm currently simulating and the flow has managed to enter the porous zone, which demonstrates indeed a porous behaviour.
a.
boundaries condition, cylindrical, multiphase, porousinterfoam, snappyhexmesh
rhoPorousSimpleFoam for modeling porous medium adiabatic flow zhzhguo OpenFOAM Programming & Development 0 August 17, 2014 23:34
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
Air flow through a porous medium Queiroz CFX 2 April 7, 2014 19:08
multiphase flow in porous media zhou FLUENT 2 August 9, 2012 08:10
Multiphase flow in porous media zhou FLUENT 0 May 10, 2005 18:45
