chtMultiRegionFoam - Thermophysical Properties error
Old   August 26, 2015, 05:30
Default chtMultiRegionFoam - Thermophysical Properties error
Tscar is on a distinguished road
may I ask how can I fix following error? Unfortunately, I was not able to find right answer in already existing threads.
My case is a flow in vertical pipe. Lower inlet air has a higher temperature and by buyoncy the air goes up. I already modeled the case with buoyantBoussinesqPimpleFoam and now i would like to add heat transfer from air to the solid pipe (wich has uniform outer temperature).
I created multi region mesh in Salome and i used following commands to export the mesh to openfoam and to create solid and fluid regions
ideasUnvToFoam meshname.unv
splitMeshRegions -cellZones -overwrite
Create time
Create fluid mesh for region fluid for time = 0
Create solid mesh for region solid for time = 0
*** Reading fluid mesh thermophysical properties for region fluid
    Adding to thermoFluid
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3   Foam::heRhoThermo<Foam::rhoThermo,  Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie>  >, Foam::sensibleEnthalpy> > > >::calculate() at ??:?
#4    Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo,   Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie>  >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh  const&, Foam::word const&) at ??:?
#5   Foam::autoPtr<Foam::rhoThermo>  Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMesh const&,  Foam::word const&) at ??:?
#6  Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#7  ? at ??:?
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9  ? at ??:?
Problems appears to be in the thermophysicalProperties dictionary for fluid region.
Thank you.
Tscar is offline   Reply With Quote
Old   August 26, 2015, 05:37
I forgot to add my termophysicalProperties file
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
mixture
    specie
        nMoles      1;
        molWeight   28.9;
    thermodynamics
        Cp          1004.5;
        Hf          274228.5;
    transport
        mu          1.71969e-05;    //13.3*1.293e-6
        Pr          0.715;
Old   August 27, 2015, 09:24
Fabian Roesler
fabian_roesler is on a distinguished road
Are you solving in parallel? If so you have to add values for temperature and pressure to all boundary fields, especially the processor fields. Otherwise you will have division by zero in the first iteration of the ideal gas law.
Cheers
Fabian
fabian_roesler is offline   Reply With Quote
Old   September 23, 2021, 12:34
Majid Mansouri
manbo is on a distinguished road
Hi!
I'm experiencing the same issue after almost seven years with version 8 of openfoam. Did you at last find what was wrong back then?
manbo is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
