SimpleFoam converged but results not acceptable |
August 24, 2015, 10:24 |
Rep Power: 11 |
Hi everybody,
I'm facing a weird problem and I haven't managed to fix it on my own so I'm asking your help. My geometry is basically two chambers connected by a helical channel, the ratio between the two cross section is roughly 100. My inlet is located at the bottom of the upper chamber, which means the velocity of my fluid (water) is multiplied by 100 in the channel. I have carried simpleFoam (and pisoFoam) simulations on different meshes. simpleFoam converged. However, when analyzing the flow at the outlet, it is obvious that the solution is not good: https://drive.google.com/file/d/0B_T...ew?usp=sharing https://drive.google.com/file/d/0B_T...ew?usp=sharing My mesh: https://drive.google.com/file/d/0B_T...ew?usp=sharing the checkMesh: Code:
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 57486 faces: 155293 internal faces: 137764 cells: 49544 faces per cell: 5.9150856 boundary patches: 11 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 46348 prisms: 1761 wedges: 0 pyramids: 0 tet wedges: 223 tetrahedra: 0 polyhedra: 1212 Breakdown of polyhedra by number of faces: faces number of cells 4 788 5 424 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology maxY 0 0 ok (empty) minX 0 0 ok (empty) maxX 0 0 ok (empty) minY 0 0 ok (empty) minZ 0 0 ok (empty) maxZ 0 0 ok (empty) Inlet 2784 2840 ok (non-closed singly connected) ChamberIn 4243 4401 ok (non-closed singly connected) Channel 3413 4080 ok (non-closed singly connected) ChamberOut 4321 4427 ok (non-closed singly connected) Outlet 2768 2840 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.047994251 -0.047981246 -4.2513276e-08) (0.047955685 0.04799059 0.024506538) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (2.1704086e-17 -5.0874776e-17 8.0606393e-16) OK. Max cell openness = 3.3265621e-16 OK. Max aspect ratio = 5.0262167 OK. Minimum face area = 1.217387e-07. Maximum face area = 5.1785612e-06. Face area magnitudes OK. Min volume = 2.6254044e-10. Max volume = 5.7125854e-09. Total volume = 0.00011854518. Cell volumes OK. Mesh non-orthogonality Max: 62.319649 average: 5.4554404 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.232373 OK. Coupled point location match (average 0) OK. Mesh OK. End Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited corrected 0.333; } interpolationSchemes { default linear; } snGradSchemes { default limited corrected 0.333; } fluxRequired { default no; p; } Code:
solvers { p { solver GAMG; tolerance 1e-7; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; } U { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } } SIMPLE { nNonOrthogonalCorrectors 0; residualControl { p 1e-3; U 1e-4; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; } } cache { grad(U); } Code:
Time = 985 smoothSolver: Solving for Ux, Initial residual = 6.38073e-05, Final residual = 5.95454e-06, No Iterations 5 smoothSolver: Solving for Uy, Initial residual = 4.56813e-05, Final residual = 4.02243e-06, No Iterations 5 smoothSolver: Solving for Uz, Initial residual = 0.000115959, Final residual = 9.89525e-06, No Iterations 5 GAMG: Solving for p, Initial residual = 5.72742e-06, Final residual = 1.15765e-07, No Iterations 2 time step continuity errors : sum local = 0.00562212, global = 0.000201768, cumulative = -1.96636 ExecutionTime = 70.03 s ClockTime = 72 s Time = 986 smoothSolver: Solving for Ux, Initial residual = 8.78342e-05, Final residual = 7.97117e-06, No Iterations 5 smoothSolver: Solving for Uy, Initial residual = 5.06628e-05, Final residual = 4.44554e-06, No Iterations 5 smoothSolver: Solving for Uz, Initial residual = 0.000128446, Final residual = 1.02145e-05, No Iterations 5 GAMG: Solving for p, Initial residual = 5.30479e-06, Final residual = 1.93503e-07, No Iterations 2 time step continuity errors : sum local = 0.00939721, global = 0.000386174, cumulative = -1.96597 ExecutionTime = 70.08 s ClockTime = 73 s Time = 987 smoothSolver: Solving for Ux, Initial residual = 6.53228e-05, Final residual = 6.50554e-06, No Iterations 5 smoothSolver: Solving for Uy, Initial residual = 4.70409e-05, Final residual = 3.94105e-06, No Iterations 5 smoothSolver: Solving for Uz, Initial residual = 9.76812e-05, Final residual = 7.99976e-06, No Iterations 5 GAMG: Solving for p, Initial residual = 4.73726e-06, Final residual = 1.7753e-07, No Iterations 2 time step continuity errors : sum local = 0.00861289, global = 0.000316105, cumulative = -1.96566 ExecutionTime = 70.14 s ClockTime = 73 s SIMPLE solution converged in 987 iterations End Finalising parallel run I'm a bit confused. |
September 1, 2015, 15:41 |
Rep Power: 11 |
have you tried to use a finer mesh? As you have propably high Re numbers, you should think about the right turbulence model for your case. Based on that it might make sense to mesh finer at the walls and in front of the outlet. Hope that helps |
September 1, 2015, 19:07 |
anonymous
Rep Power: 13 |
Increase the nNonOrthogonalCorrectors and reduce the residual control because your values are too high. Moreover are you sure that your flow is not turbulent?
September 2, 2015, 10:56 |
Rep Power: 11 |
Here a new mesh I generated (roughly 6 000 000 cells) where I refined in the previous divergence area:
https://drive.google.com/file/d/0B_T...ew?usp=sharing but the checkMesh gives some bad results (5 failed checks): Code:
Mesh stats points: 6171314 faces: 17650093 internal faces: 17175464 cells: 5753314 faces per cell: 6.05313 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 5418331 prisms: 52953 wedges: 0 pyramids: 0 tet wedges: 364 tetrahedra: 0 polyhedra: 281666 Breakdown of polyhedra by number of faces: faces number of cells 4 27801 5 13491 6 7905 7 124544 8 45159 9 55767 10 19 11 4 12 5678 15 1152 18 146 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Inlet 34141 35141 ok (non-closed singly connected) ChamberIn 122844 123527 ok (non-closed singly connected) Channel 112119 136825 ok (non-closed singly connected) ChamberOut 122845 123515 ok (non-closed singly connected) Outlet 82680 83122 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.0489987 -0.049 -1.8272e-07) (0.049 0.049 0.0245002) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-2.00751e-16 1.09013e-16 4.71144e-14) OK. ***High aspect ratio cells found, Max aspect ratio: 6.63345e+192, number of cells 12632 <<Writing 12632 cells with high aspect ratio to set highAspectRatioCells Minimum face area = 2.60377e-11. Maximum face area = 4.33051e-07. Face area magnitudes OK. ***Zero or negative cell volume detected. Minimum negative volume: -1.2117e-11, Number of negative volume cells: 12632 <<Writing 12632 zero volume cells to set zeroVolumeCells Mesh non-orthogonality Max: 180 average: 10.0422 *Number of severely non-orthogonal (> 70 degrees) faces: 16484. ***Number of non-orthogonality errors: 40913. <<Writing 57397 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 95678 faces are incorrectly oriented. <<Writing 65404 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 102532, 5329 highly skew faces detected which may impair the quality of the results <<Writing 5329 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 5 mesh checks. End Code:
[0] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #2 in "/lib/x86_64-linux-gnu/libc.so.6" [0] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? [0] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? [0] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [0] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [0] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? [0] #8 [0] at ??:? [0] #9 [0] at ??:? [0] #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [0] #11 [0] at ??:? [mp13305-All-Series:10557] *** Process received signal *** [mp13305-All-Series:10557] Signal: Floating point exception (8) [mp13305-All-Series:10557] Signal code: (-6) [mp13305-All-Series:10557] Failing at address: 0x3e90000293d [mp13305-All-Series:10557] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36d40) [0x7f8f2110bd40] [mp13305-All-Series:10557] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x7f8f2110bcc9] [mp13305-All-Series:10557] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36d40) [0x7f8f2110bd40] [mp13305-All-Series:10557] [ 3] /opt/openfoam231/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xbe) [0x7f8f22256e9e] [mp13305-All-Series:10557] [ 4] /opt/openfoam231/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x222d) [0x7f8f2225b74d] [mp13305-All-Series:10557] [ 5] /opt/openfoam231/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x4ae) [0x7f8f2225c32e] [mp13305-All-Series:10557] [ 6] /opt/openfoam231/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x132) [0x7f8f23fa32c2] [mp13305-All-Series:10557] [ 7] simpleFoam(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x14f) [0x44678f] [mp13305-All-Series:10557] [ 8] simpleFoam() [0x446aba] [mp13305-All-Series:10557] [ 9] simpleFoam() [0x41b9a1] [mp13305-All-Series:10557] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f8f210f6ec5] [mp13305-All-Series:10557] [11] simpleFoam() [0x41c5a0] [mp13305-All-Series:10557] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 0 with PID 10557 on node mp13305-All-Series exited on signal 8 (Floating point exception). I have done your modifications for thefvSolution file. And for sure the flow is turbulent (Re=100 000 in the channel), I use the realizable k-epsilon model. Thanks for the help! |
September 2, 2015, 11:20 |
#5 | |
Rep Power: 11 |
That makes it easier. You can do that with the command Code:
objToVTK -help |
September 2, 2015, 11:58 |
Rep Power: 11 |
Ok so the zeroVolumeCells check mesh should be the reason for the crash.
Here's there location. So it looks like a boundary issue right? Maybe the mesh is too fine? https://drive.google.com/file/d/0B_T...ew?usp=sharing I used the following code line to display the set in ParaView: Code:
foamToVTK -cellSet zeroVolumeCells |
September 2, 2015, 13:15 |
Rep Power: 11 |
that could solve the problem. By the way, how do you mesh your geometry? Do you use snappyHeymesh?
September 2, 2015, 13:18 |
Rep Power: 11 |
SnappyHexMesh, implicit way (just one stl file with regions defined in it)
Problem: Very long "write" time (~2h-3h) for results and transient results | Shawn_A | CFX | 16 | April 12, 2016 21:49 |
long period oscillations in simpleFoam results | james.conger | OpenFOAM Running, Solving & CFD | 5 | August 23, 2014 11:50 |
tet results vs hex results | sivakumar | OpenFOAM Running, Solving & CFD | 0 | March 4, 2014 11:15 |
simpleFoam vs LTSInterfoam for submerged object | ynos | OpenFOAM Running, Solving & CFD | 0 | January 17, 2014 08:44 |
Laminar simpleFoam and inviscid simpleFoam | herenger | OpenFOAM Running, Solving & CFD | 7 | July 11, 2013 07:27 |
