Pruthvi
Rep Power: 12 ![]() |
Hello all,
I ran the case of a pitching and plunging flat-plate and i'm trying to establish time-step independence. As I reduce the time-step I notice spikes in the force curve. What is the reason behind these spikes? Please take a look at the force plots below. time_independence_fullview.jpg time_independence.jpg Here are the schemes I'm using. Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; } divSchemes { default none; div(phi,U) Gauss linearUpwind grad(U); div(phi,k) Gauss limitedLinear 1; div(phi,omega) Gauss limitedLinear 1; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited corrected 0.5; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; pcorr ; p; } Here is a screenshot of the mesh i'm using. The flat plate is modelled using the createBaffle utility. Meshing with gmsh. flatplate_closeup.jpg flatplate_extruded.jpg |
baffle, mesh independence, pimpledymfoam, time independence |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Rapidly decreasing deltaT for interDyMFoam | chrisb2244 | OpenFOAM Running, Solving & CFD | 3 | July 1, 2014 16:40 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 09:20 |
