Wrong values next to a surface with stepwise property function
Old   August 17, 2015, 11:01
Default Wrong values next to a surface with stepwise property function
Marcel Bornstein
Siegunn is on a distinguished road
Dear Foamers,
i'm working with a simple steadystate-solver for calculating the current density within a conductor.
The solved equation is fvm::laplacian(sigma,V),where V is the electrostatic potential and sigma is the conductivity. The current density J is simply calculated by J=sigma*(-fvc::grad(V)).
In principle the solver works fine but in the case of an 1-dimensional resistor a problem appears at the cells next to a surface with a step in sigma, which can be seen in the attached picture below. The highlighted cellvalues correspond to the calculated current density, which should be homogenous over the whole volume.
I think this problem comes from a missing boundary condition at this surface, which should be something like this:
n * (J_a-J_b)=0,
where n is the surface normal vector and J_a, J_b the current densities of both sides to the surface.
Actually i have no idea how to set this boundary condition, because it is not a static value or gradient. Could someone give me a hint to this problem?
Cheers
Marcel
Siegunn is offline   Reply With Quote
[OpenFOAM] Probes function gives different values than ParaView Bazinga ParaView 4 November 29, 2017 14:59
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
surface tension gradient using UDF; surface tension gradient as function of temperatu marimuthusundar Fluent UDF and Scheme Programming 0 June 21, 2012 05:48
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
