wrong token type - expected Scalar, found on line 0 the word 'nan'
Old   August 11, 2015, 09:22
Default wrong token type - expected Scalar, found on line 0 the word 'nan'
as
anuja is on a distinguished road
Hi I am getting this error
file: C:/OpenFOAM/cygwin64/home/mahaanu/OpenFOAM/mahaanu-2.3.x/run/trial_plate2/system/data.solverPerformance.p_rgh at line 0.
From function operator>>(Istream&, Scalar&)
in file lnInclude/Scalar.C at line 93.
I am trying to solve a porousInterFoam problem with the following boundary conditions for resin as the fluid. Can you please tell me where I am going wrong?
Thanks in advance!
P_rgh
boundaryField
FrontAndBack
type empty;
atmosphere
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho rho;
psi none;
gamma 1;
value uniform 0;
lowerWall
type fixedFluxPressure;
value uniform 0;
leftWall
value uniform 0;
rightWall
value uniform 0;
porosityWall
value uniform 0;
U
boundaryField
FrontAndBack
type empty;
atmosphere
type pressureInletOutletVelocity;
value uniform (0 0 0);
lowerWall
type fixedValue;
value uniform (0. 0. 0.);
leftWall
type fixedValue;
rightWall
type fixedValue;
porosityWall
type slip;
alpha.resin
boundaryField
leftWall
type zeroGradient;
rightWall
type zeroGradient;
lowerWall
type zeroGradient;
porosityWall
type zeroGradient;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
FrontAndBack
type empty;
Regards.
anuja is offline   Reply With Quote
Old   August 12, 2015, 10:26
Nicole Andrew
Nicole is on a distinguished road
I am no expert, but looking at your error message and trying to decode it:
1) "nan" is usually "Not a number" and is not a good thing
2) I have never seen a case structure with "system/data.solverPerformance.p_rgh" (but this may be due to my inexperience)
You did not give very much info, some follow up questions:
1) When do you get this error? As you run the case? After some iterations?
2) What files do you have in your "system" folder in your case setup?
Nicole is offline   Reply With Quote
wrong token type - expected Scalar, found on line 0 the word 'nan' CrisMoreira OpenFOAM Running, Solving & CFD 0 July 9, 2015 10:15
Error during initialization of "rhoSimpleFoam" kornickel OpenFOAM Running, Solving & CFD 8 September 17, 2013 06:37
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
