rhoSimplecFoam
Old   August 8, 2015, 11:13
Question rhoSimplecFoam
Giles Richardson
ufocfd is on a distinguished road
Hi guys, I'm trying to use rhoSimplecFoam from the OpenFOAM v2.1.x distribution (therein lies the problem).
It keeps crashing after a few iterations, with what seems to be a density spike, causing the epsilon equation to crash. When I view the solution from just before the crash, I see a high density cell just upstream of the aircraft. I'm imposing limits on the density (0.5min and 2.0max) within the fvSolution file.
Has anyone actually got rhoSimplecFoam (or rhoSimpleFoam for that matter) to work??? My testcase is an aircraft at 100m/sec and I'm using freestream boundaries. rhoSimpleFoam does not even get past the 1st iteration.
I think its likely something to do with the fvSchemes and fvSolution file settings... any help much appreciated. Thanks.
ufocfd is offline   Reply With Quote
Old   August 8, 2015, 13:04
Giles Richardson
...and it seems to have something to do with the location specified in pRefPoint:
pRefPoint (-15 35 35);
pRefValue 100000;
Old   August 9, 2015, 14:34
Giles Richardson
Finally got rhoSimpleFoam working for an aircraft at 100m/sec.
Having consistent boundary conditions, and turbulence values,
seems to be the key factors, and not using pRefPoint also.
Got a nice convergence plot from rhoSimpleFoam below.
Old   November 5, 2018, 06:24
vale94 is on a distinguished road
Hi ufoCFD,
I know quite a lot time has passed, but do you still have the fvschemes and fvsolution to post? I'd like to know how you obtained such a beautiful convergence! Thank you
vale94 is offline   Reply With Quote
Old   November 5, 2018, 09:55
Giles Richardson
I will have a look for them...
Old   November 5, 2018, 10:43
Giles Richardson
| \\ / O peration | Version: 2.1.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div((muEff*dev2(T(grad(U))))) Gauss linear;
div(phi,h) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,k) Gauss upwind;
div(phid,p) Gauss upwind;
div(phi,K) Gauss upwind;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
UD upwind phid;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
pCorr;
Old   November 5, 2018, 10:44
Giles Richardson
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver GAMG;
tolerance 1e-08;
relTol 0.1;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
cacheAgglomeration true;
nCellsInCoarsestLevel 20;
agglomerator faceAreaPair;
mergeLevels 1;
"(U|h|k|epsilon)"
solver GAMG;
tolerance 1e-08;
relTol 0.1;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
mergeLevels 1;
SIMPLE
nNonOrthogonalCorrectors 0;
rhoMin rhoMin [1 -3 0 0 0] 0.5;
rhoMax rhoMax [1 -3 0 0 0] 2.0;
transonic no;
relaxationFactors
fields
p 0.3;
rho 0.1;
equations
// pEqn 0.3;
U 0.5;
h 0.5;
k 0.5;
epsilon 0.5;
Old   November 5, 2018, 10:47
Giles Richardson
Those (supplied) are the fvSchemes and fvSolution for the rhoSimple solver.
I have also done same for rhoSimplec solver if you need them.
Contact me on garcfd (at) gmail (dot) com if you need any help.
Old   November 5, 2018, 16:13
Thank you very much!
Old   May 15, 2024, 05:27
witega is on a distinguished road
Hi ufoCFD,
I know quite a lot time has passed, but do you have also the consistent boundary condition to post? I'd like to know how you obtained such a beautiful convergence, because I'm having a lot of trouble with rhoSimpleFoam! Thank you
witega is offline   Reply With Quote
Old   May 15, 2024, 08:27
Giles Richardson
message me on garcfd@gmail.com and I can look into it for you...
openfoam2.1.x, rhosimplecfoam, rhosimplefoam
Big problem predicting adiabatic wall temperature (wing, mach 0.33, rhoSimplecFoam) fredo490 OpenFOAM Running, Solving & CFD 7 May 12, 2022 03:24
rhoSimplecFoam with setFields sino75 OpenFOAM Pre-Processing 0 March 11, 2015 05:08
using GAMG in rhoSimplecFoam tutorial. why? Farshad_Noravesh OpenFOAM 0 November 21, 2012 02:38
rhoSimpleFoam versus rhoSimplecFoam jeff.freeman OpenFOAM Running, Solving & CFD 1 September 18, 2012 10:23
rhoSimplecFoam U-turn j-blindi OpenFOAM Running, Solving & CFD 6 October 29, 2011 18:21
