Parallel Processing by region
Old   July 30, 2015, 09:42
Default Parallel Processing by region
Thomas Sprich
Swift is on a distinguished road
Greetings to the Forum,
I have adapted the propeller example to suite my test case which is a mixer in a tank. I have a stator domain (region0) and a rotor domain (region1). I am able to run the model on a single core as well as in parallel processing. I notice however, that the parallel case is taking longer to solve than when it solves on a single core. I suspect it has to do with the way the solution is divided between the processors. I edited the decomposeParDict from the propeller example as follows to reflect the new orientation of my case:
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      decomposeParDict;
numberOfSubdomains 3;
method          hierarchical;
hierarchicalCoeffs
    n               (1 1 3);
    delta           0.001;
    order           xyz;
/*numberOfSubdomains 3;
method          scotch;
distributed     no;
roots           ( );
You can see that this will divide the case in the z direction rather than the y direction like the propeller case.
I also tried the "scotch" method that is commented out in the code above.
I suspect the reason the parallel processing is taking longer is because of the way the solution is being divided up.
I would like to know if it is possible to to divide the solution such, that the stator region solves on one processor and the rotor region on the other. I realise that this would mean I only use two processors but I would like to see if this would improve the solution.
Thanks in advance for the help!
Thomas
Swift is offline   Reply With Quote
Some questions about a multi region case run in parallel zfaraday OpenFOAM Running, Solving & CFD 5 February 23, 2017 11:25
problem for parallel processing minaret OpenFOAM Running, Solving & CFD 14 January 20, 2015 00:41
Fluent 15.0 Parallel and Batch Processing on a Supercomputer n_bowen FLUENT 0 August 26, 2014 14:46
Paradox in parallel processing Vagelis FLUENT 0 October 26, 2005 06:36
About parallel processing in Linux tuks CFX 10 August 8, 2005 09:22
