July 26, 2015, 18:07 |
Problem running PimpleDyMFoam
Rep Power: 11 |
Hi everyone! I'm trying to model a running turbine in OpenFoam. I'm using a library that I compiled based on the angularOscillatingVelocity. I simply removed the oscillating part and changed the equation scalar angle = angle0 + amplitude*sin(omega*t.value()) to scalar angle =angle= + omega*t.value()
My cellMotionU dictionary is: boundaryField { default { type empty; } inlet { type fixedValue; value uniform (0 0 0); } outlet { type fixedValue; value uniform (0 0 0); } down { type fixedValue; value uniform (0 0 0); } up { type fixedValue; value uniform (0 0 0); } front { type fixedValue; value uniform (0 0 0); } back { type fixedValue; value uniform (0 0 0); } turbine_patch28539 { type rotatingWallVelocity; axis (1 0 0); origin (0 0 0); angle0 0; omega 20.94 value uniform (1 0 0); } and my U dictionary is: boundaryField { inlet { type fixedValue; value uniform (1 0 0); } outlet { type fixedValue; value uniform (0 0 0); } down { type fixedValue; value uniform (0 0 0); } up { type fixedValue; value uniform (0 0 0); } front { type fixedValue; value uniform (0 0 0); } back { type fixedValue; value uniform (0 0 0); } turbine_patch28539 { type fixedValue; value uniform (0 0 0); My fvSolution is: solvers { pcorr { solver GAMG; tolerance 1e-06; relTol 0.01; smoother DICGaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; maxIter 50; } p { $pcorr; tolerance 1e-6; relTol 0.01; } pFinal { $p; tolerance 1e-6; relTol 0; } cellMotionU { solver GAMG; smoother DICGaussSeidel; tolerance 1e-07; reTol 0; cacheAgglomeration no; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; maxIter 50; } U { solver GAMG; smoother DILUGaussSeidel; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; cacheAgglomeration true; tolerance 1e-6; relTol 0.1; } UFinal { $U tolerance 1e-6; relTol 0; } /* "(U|k|omega)" { solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0.1; } "(U|k|omega)Final" { $U; tolerance 1e-06; relTol 0; } */ k { solver PBiCG; preconditioner DILU; relTol 0.1; } } PIMPLE { correctPhi yes; nOuterCorrectors 2; nCorrectors 3; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; } relaxationFactors { fields { } equations { "U.*" 1; } } When I run moveMesh everything is ok, but when I run mpirun -np 8 pimpleDyMFoam -parallel I have a problem when it gets to the part that needs to solve the U equation Solving for Ux, Initial residual = -nan, Final residual =nan, No Iterations 1001 I've tryed to changed the solvers but that always happens... can anyone help me? |
August 18, 2015, 11:44 |
Use Propeller Tutorial
Werner
Rep Power: 11 |
Hi ! ,
I'm sorry to tell you I can't help you very much with my shallow knowledge of OpenFoam, since I haven't experienced such problem before, But I have a couple questions that may guide you. I'm simulating an axial turbine as well and I just imitated the propeller case of the tutorials. According to that case you must define a Cylinder that contains your turbine and with which the sliding mesh rotates. Do you have such Cylinder somewhere ? If not, since I don't see it in the boundaries, how are you defining the sliding mesh? Regards, Werner |
September 21, 2016, 04:24 |
Rep Power: 11 |
I know this is a old thread, but nonetheless:
-Your U boundaries, as far as I can see, only have an inflow, but no face that allows the flow to exit. -The way you approach this looks like a deforming mesh to me (but knowing your boundary and dynamicMeshDict would help. This is something I recommend not to do. Your deformation will be too much. Use a slidingMesh, if possible, instead. It allows rotation and does not require any changes in your cellMotionU |
pimpledymfoam |
Problem running movingCylinders case in parallel with foam-extend-3.1 | mhkenergy | OpenFOAM Running, Solving & CFD | 5 | March 3, 2017 06:20 |
Problem with parallel run of my solver based on pimpleDyMFoam | o.kotsur | OpenFOAM Running, Solving & CFD | 0 | October 6, 2013 04:44 |
Problem while running in Highperformance computing environment | Phanipavan | STAR-CD | 1 | September 11, 2013 07:42 |
problem with running in parallel | dhruv | OpenFOAM | 3 | November 25, 2011 06:06 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
