July 23, 2015, 15:52 |
Pressure/Velocity Boundary conditions
Lori
Rep Power: 11 |
Hi everyone,
I have a question regarding pressure and velocity boundary conditions. I have a case where there are two channels separated by a membrane. I know the applied pressure to the inlets and the initial flow rates. So, I set the pressure inlet BC to total pressure where p0 is the applied pressure, and I used swak4foam to set a parabolic inlet velocity with the average velocity from the known flow rate. So, my big question is how should I set appropriate outlet BCs for pressure and velocity? I wanted to set the pressure outlet to fixedValue and say the value is $internalField, but when I did that I got an error saying that "compound has already been transferred from token" and I have not been able to even figure out what that error means. So, any suggestions on appropriate BCs? Thankyou for replying in advance Lori |
boundary condition, openfoam, total pressure, velocity |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 10:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
